Silvertop oil pump upgrade?
Old Aug 23, 2010 | 02:28 PM
percybigun's Avatar
percybigun
Twistin me melon man
Default Silvertop oil pump upgrade?
I see CFM do a billet oil pump gear for the blacktop oil pump, but are there any uprated ones for the silvertop?
Or am i safe sticking with the standard oil pump, its a supercharged 2.0 silvertop which will be running circa 250bhp (non intercooled, but has water injection and i will be fitting an oil cooler soon as i had been having high oil temps). Also it will be running an occasional 50 shot of nitrous.
Rev limit is at 7200rpm but i rarely go there
Old Aug 23, 2010 | 02:42 PM
chaffe's Avatar
chaffe
Turbocharging Technician
standard oil pump is more than adequate, there was a lot of problems with early zetecs and the followers jacking up when they were cold, with excess oil pressur, hence ford changed the oil to pish thin 5w 30, and there was a mod to the relief valve in the pump, and a change to the follower design, and especialy as you have no turbo bleeding off oil, im sure your standard pump is ample, just keep an eye on your oil temps as mentioned.
Old Aug 25, 2010 | 09:27 AM
percybigun's Avatar
percybigun
Ok nice one, i think i will fit a new oil pump anyway because its had most of the other ancillaries renewed
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
talon1
Sep 15, 2015 10:27 AM
focus2351
Sep 9, 2015 09:33 PM
