205 short motor value??
Old Aug 23, 2010 | 06:01 AM
BRAMMER's Avatar
BRAMMER
Default 205 short motor value??
Not a sale advert as it still running in my car but......
The block is a 205 short motor rebuilt by Gordon Scott in 2008 and has cover 3300 miles. 1000 miles were covered around the lake district up and down hills to get the engine working. The receipts i have for the rebuild parts state STD size and all genuine Ford from Woodford Garage.
The motor is fine and produces good oil pressure, going by the readings it's on a standard pump and as far as i'm aware it's STD internals.
What sort of cash do these fetch in STD size?
Cheers for help
Old Aug 23, 2010 | 08:15 AM
cossie891's Avatar
cossie891
Ł600 would be my guess mate
Old Aug 23, 2010 | 09:04 AM
RS500/364's Avatar
RS500/364
That would be what i would pay if buying 205 as everyone wants 200 long stud ex
i would do a deal on my 200 use none turk block maybe !
Old Aug 23, 2010 | 12:47 PM
If I were in a position to need to buy a short block such as yours, I'd pay more possibly up to Ł1K, but that's just my opinion, by the time you add all the parts cost up I think it is still a good deal.
I'm just rebuilding my 205 block at the moment, that did 200,973 miles and is still on std crank big ends and mains, and now 1st oversize pistons, crank was polished but really could have got away without that.
Old Aug 23, 2010 | 12:50 PM
R4N SS's Avatar
R4N SS
you can rebuild it yourself for that.
reckon 600 is a good price.
Old Aug 23, 2010 | 01:02 PM
BRAMMER's Avatar
BRAMMER
The reason i ask is because i'm trying to work out if it's worth swapping all the internals from my block to my new 200 block or sell complete and buy replacement bit's.
Old Aug 23, 2010 | 02:10 PM
R4N SS's Avatar
R4N SS
cheaper to swap your bits over but then it wont be a fresh engine then.
i have a monkey waiting for your engine - pm me if need be
Old Aug 23, 2010 | 04:56 PM
BRAMMER's Avatar
BRAMMER
What a monkey? really
Old Aug 23, 2010 | 05:00 PM
james kiely's Avatar
james kiely
i will give you a couple of boxer dogs chris ,their getting on a bit but are more useful than a monkey
Old Aug 23, 2010 | 05:26 PM
LHD220Turbo's Avatar
LHD220Turbo
block = Ł100
crank = Ł300-Ł400 if standard size
rods = Ł100
pistons = Ł80-Ł100
i'd say Ł750 if i was selling it as complete.
personally tho, i would use the crank in your new build rather than buying another; the crank is worth the most (assuming it stays on standard grind and is in excellent cond.)
Old Aug 23, 2010 | 05:52 PM
cossie891's Avatar
cossie891
Ł750 is normally for a fresh bottom end tho fella a monkey is about right
Old Aug 23, 2010 | 06:11 PM
BRAMMER's Avatar
BRAMMER
I'll be keeping it as it would cost me more to source a crank in std size, rods, sump, pulley's.
Old Aug 23, 2010 | 09:25 PM
AndyPen's Avatar
AndyPen
Seen em go on ebay around the Ł500 mark too. Was considering selling my spare 205 motor but some complete ones went for a grand at the time.
Old Aug 23, 2010 | 10:35 PM
R4N SS's Avatar
R4N SS
coonts
Old Aug 24, 2010 | 04:44 PM
I think the point you miss is yes you can rebuild one for that, but that is when you already have one, if you don't and you are buying one for whatever reason outright then considering it is effectively new I'd pay more, so someone faced with sourcing a engine for a project with nothing to start with a effectively new bullet proof short motor has got to be worth that imo, esp if with alt starter ps pump etc etc.
But with money the way it is at the mo, who knows, even selling anything these days is a challenge!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
