cooling fan wire's HOT
Old Aug 22, 2010 | 03:52 PM
john_d's Avatar
john_d
Default cooling fan wire's HOT
i have my cooling fan wired up to a manual switch, i noticed that when the fan is on the wire gets hot, perhaps too much volts going through it or is this normal?
Old Aug 22, 2010 | 06:09 PM
martysmartie's Avatar
martysmartie
Having the fans on a manual switch is not a good idea, it's only takes for you to forget etc and it's a costly mistake, hence why the system was automated to start with.
The wiring will get warm due to the amount of current the fans draw. This is why they should not be on for any longer than they need to be?
How long are they on for when the wiring gets hot?
Martin
Old Aug 22, 2010 | 06:17 PM
john_d's Avatar
john_d
erm 10 seconds,
its a resto im doing so it not permanat, i just wanna make sure the engine doesnt over heat when i run the engine every now and then
Old Aug 22, 2010 | 06:25 PM
martysmartie
Are you using your switch to just trip the relay (Original design) or have you run your own wiring to power the fans themselves?
Martin
Old Aug 22, 2010 | 06:28 PM
john_d's Avatar
john_d
my own wiring............................................ .........................straight to the battery
Old Aug 22, 2010 | 06:42 PM
martysmartie
Thought as much, I would suspect the wiring, what gauge are you using?
As I say the fans draw alot of power, if it's piddy wiring it will melt it.
Martin
Old Aug 22, 2010 | 06:54 PM
john_d's Avatar
john_d
its the original wiring on the fan im using, i just have no plug on the end.
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Flatlinedan
Sep 18, 2015 12:41 PM
StephTell
Sep 2, 2015 06:31 PM
