8v DOHC kit car project
Old Aug 22, 2010 | 01:40 AM
alexno1dj's Avatar
alexno1dj
Default 8v DOHC kit car project
Hi folks building a westfield/lotus 7 replica,
Got wheels, coilovers and engine all in. What part of the loom will be required just to get engine started. Im not sure if people are aware that it is mechanical ignition so surely its just a case of getting fuel system sorted? cheers
Old Aug 22, 2010 | 01:49 AM
alexno1dj's Avatar
alexno1dj
The engine is out of a Sierra and im told its a pretty decent unit. I4 i think, altho its got 200 stamped on the block
Old Aug 22, 2010 | 06:22 AM
Mike Kerbey's Avatar
Mike Kerbey
Its a great torquey engine and will go nicely in a westfield type kit car. By mechanical ignition do you just mean the distributor cap and rotor arm? If you have the engine wiring loom and ecu it should just simply be plug and play.
manuel boeckx
13
Oct 3, 2015 02:29 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
Adam-M
22
Aug 10, 2015 10:46 AM
knight19770
Aug 4, 2015 12:36 PM
