cosworth fuel pressure
Old Aug 21, 2010 | 04:19 PM
gareth d's Avatar
gareth d
Question cosworth fuel pressure
Hello i have a 2wd saff cosworth running dark green injectors t34 rs 500 style intercoller 044 pump the inlets have been opend up on the head and its got a steel cometic head gasket and all the rest of the stuff to go with it. ime looking at running about 340BHP will i need to turn up the fuel pressure.ive put a gauge on it and its on 3.5bar with the pipe on.
Old Aug 21, 2010 | 04:34 PM
oldford's Avatar
oldford
You should ask the programmer/mapper/tuner of the eprom this question.
But more power is not possibly without remapping.
Old Aug 21, 2010 | 05:17 PM
gareth d's Avatar
gareth d
Smile cosworth fuel pressure
ive seen a chip made by motorsport deveopments on e bay i think ill contact them.thankyou
Old Aug 21, 2010 | 05:34 PM
oldford's Avatar
oldford
You want to blow up the engine in the biggest way possible? Then go ahead and buy from flea-bay. Personally I think you could better donate that money to the Red Cross. Then it will serve a purpose.
Get the car live mapped by somebody who knows what he is doing.
Old Aug 21, 2010 | 05:40 PM
Toe Knee's Avatar
Toe Knee
He said it was a chip by Motorsport developments, which is stu off here so why would it blow up?! As long as it is one of his chips and matches the spec of ur car you'll be fine but it will still reguardless need setting up after properly by a tuner yo make sure it's not leaning out when driving. Doesn't need livemapping which isn't cheap but obviously if u can afford it is the best way to go to get the best out ur car.
Old Aug 21, 2010 | 05:59 PM
oldford's Avatar
oldford
How are you going to verify the fact this is a chip made by motorsport developments?
If the engine doesn't blow it has to be one?
Or can you read eproms over a phone line before buying and look at the programming methods and style?
Old Aug 21, 2010 | 06:33 PM
gareth d's Avatar
gareth d
the chip is from motorsport developments on line shop on ebay. Ł140 340bhp+
Old Aug 21, 2010 | 06:55 PM
Toe Knee's Avatar
Toe Knee
Ermmm cos they sell them on eBay?! Lol
Old Aug 21, 2010 | 06:58 PM
oldford's Avatar
oldford
Well, forgive me for being suspicious.
I am from an era where the major seller of chips for road cars had the nickname "Destruction Techniques". You can probably guess why.
And "tuners" were selling Group A Ford Motorsport chips (camshaft, greys, 3-bar etc.) as a road chip for standard cars claiming it would give 280bhp. One of those "tuners" wanted me to copy the eproms for him for a tenner, provided I would supply the eproms.
I declined, because Industrial grade eproms were more expensive than that. He said commercial grades would also do the job. Yeah, Right. Until the 2nd day of your wintersport holiday and the car refuses to start.
Prickly_buzz
Aug 25, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
