Would it cause the car damage by removing the bottom........
Old Jan 22, 2005 | 05:33 PM
Dev's Avatar
Dev
Default Would it cause the car damage by removing the bottom........
The bottom throttle body sensor? as i have been told todo so to stop the tick over problem where it goes up and down constantly like someone it slightly taping the accelerator!
Old Jan 22, 2005 | 05:37 PM
sammy's Avatar
sammy
no it wont cause damage to remove/refit, throttle position sensor (tps) by the way (you need to have one though!)
Old Jan 22, 2005 | 05:45 PM
Dev's Avatar
Dev
oh, i was told to disconnect it. "not remove it hehehe"
Old Jan 22, 2005 | 06:02 PM
Dev's Avatar
Dev
do i definitaly need to replace it? if so is there anywhere on the net i can get one for a MK6 escort 1.8si?
Old Jan 23, 2005 | 10:38 AM
Dev's Avatar
Dev
anyone?
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
