Zetec turbo RWD which inlet?
Hi all,
i have recently purchased a E21 bmw and i want to remove the 1.8 currently fitted and put a 2.0 zetec turbo in it,
only i cant find a inlet manifold that will have the throttle body at the front of the engine when fitted, i know the common one used is rover turbo inlet but the throttle body will be the wrong end of the engine.
has anyone got a ZT RWD if so what inlet have you used?
any help/info would be great
cheers
steve
cheers
steve
what sort of power was yours making?
i done one before with a efi inlet and it made 230bhp, but i dont want the inlet pipe to run ove rthe top of the engine really.
im considering a area six inlet as i want about 340-360 reliable bhp
steve
steve
get in touch with kit car company's mate as they all use zetec engine's. If you write zetec plenum in ebay it'll come up a company called pepperperformance. They make them for turbo use with map sensor ports ect.
big_Rad
Sep 15, 2017 09:36 AM
