cossie ignition systems check problem?
Old Jan 22, 2005 | 01:26 PM
DooerEvo1's Avatar
DooerEvo1
Default cossie ignition systems check problem?
I've got a 91 4x4 saff. and a few weeks ago when you turn the ignition on the systems check with the picture of the car (tells you when doors are open and lights are out etc.....)and the fuel low warning light and low water level lights,have decided not to work until about 20mins into the journey.I've swapped the actual displays with another cossie and they all work fine on the other car,i've wiggled and checked wiring with no luck anyone any ideas?Is there a control box anywhere that controls this system?
van_dogg_pavvy
Mar 3, 2016 09:30 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
