Piston Protrusion!
Old Jan 22, 2005 | 10:39 AM
vyper developments's Avatar
vyper developments
Default Piston Protrusion!
Hi all,
I am just rebuilding my 1990 2wd 205 motor, as things were getting smokey and oil consumption was high.
It was all standard so have gone for 0.5 rebore as bores were a little oval and oil control rings shot. I am in the throws of re-assembling the engine and have noticed that at TDC I have 22 thou (0.51mm) piston protrusion out the top of the block, obviously this is on all 4.
I did'nt seem to notice this amount when I stripped the motor down! Does anybody know if this is right or wrong. I dont want to end up with compression problems. I will be using a cometic head gasket at 1.4mm thick. Thanks, Mike.
Old Jan 22, 2005 | 11:02 PM
markk's Avatar
markk
its a very long time since i built a std cos motor, but im 99.9% sure that .5mm protrusion is correct at std,
please bare in mind c.r increases wit overbore !!!
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
