Cabriolet
Old Aug 16, 2010 | 06:51 PM
burnhamshaun's Avatar
burnhamshaun
Default Cabriolet
I've got A mark 4 escort cabriolet trying to find out why the roof don't work any ideas when I press the switch button there is a clicking noise coming from the boot I've also noticed that the oil for the hydraulic pump is below minimum could this be the only cause as there isn't even the slightest of movement
Old Aug 16, 2010 | 07:30 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
There is also a couple of relays behind the light cover. Take them out and make sure there clean
Old Aug 16, 2010 | 07:35 PM
burnhamshaun
Ok will give that a go tomorrow would it still work with oil below minimum or not
Old Aug 16, 2010 | 07:41 PM
burnhamshaun
What oil would I need to buy to top up cheers for help advice
Old Aug 19, 2010 | 04:26 PM
burnhamshaun
up
Old Aug 19, 2010 | 05:00 PM
STeve's Avatar
Super Moderator
common for pumps to pack up ,you may find oil under your carpet
Old Aug 19, 2010 | 05:12 PM
burnhamshaun
ill have a look over the weekend all i know is that the oil resvoir is below the minimum and when i touch the switch there is a clicking sound coming from the back of the car other then that nothing is there any way of testing the pump and what oil do i use if i do get it working
Old Aug 19, 2010 | 05:16 PM
s1cab's Avatar
s1cab
im sure its just hydraulic oil same as if u were to fill a jack/engine hoist up.
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
23
Sep 12, 2015 12:56 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
bigryrs
Sep 7, 2015 06:45 PM
