Fault codes please. C140
Old Aug 13, 2010 | 05:09 PM
stupink's Avatar
stupink
Default Fault codes please. C140
Hiyas,
Just read the fault code on my 1.4tdci 56 fiesta and its come up with a chassis fault of C140.
I've only been able to find a list of the powertrain faults so dont know what this referrs to.
The problem itself is powerloss at higher rpm 4-6times a day for a second.. I think im narrowing it down to an issue something to do with the alternator system.
Thanks for any help
Old Aug 13, 2010 | 05:59 PM
oldford's Avatar
oldford
C140 could be code U0140 if it's a powertrain code.
That's a network error: Lost Communication With Body Control Module
With what software or scanner did you read the code?
Old Aug 13, 2010 | 09:19 PM
stupink's Avatar
stupink
I read it from the dashboard directly by scrolling through the test mode
It was clear, then the fault happened long enough to bring the ecu light on briefly, and then the code was stored
The alternator light came one once apparently for 30s or so , but i wasnt driving it at the time to see.
tankybaby66
Feb 6, 2016 02:24 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Si B
Sep 12, 2015 06:49 AM
