brakes sticking
Old Aug 13, 2010 | 12:21 PM
cossie.087's Avatar
cossie.087
Default brakes sticking
helleo again more problems.
rear brakes sticking on slightley,and causing discs, pads and rim to reden.
changed calipers same story any help welcome.
thanks cossie.087.
Old Aug 13, 2010 | 12:23 PM
rog's Avatar
rog
New discs and pads or using old ones? How tight is the handbrake? When you jack up the car does the rear wheel spin freely?
Old Aug 13, 2010 | 12:29 PM
Luca's Avatar
Luca
Lukesville
what car ?? and pedal box??
Old Aug 13, 2010 | 01:20 PM
cossie.087's Avatar
cossie.087
hi rog
discs and pads s few months old handbrake disconnected.when i brake hard brakes stay on for about ten seconds then slacken off but still slightley stick on.
Old Aug 13, 2010 | 01:21 PM
cossie.087's Avatar
cossie.087
hello luca.
saff 4x4
Old Aug 13, 2010 | 02:44 PM
rog's Avatar
rog
Hmmm, I'm not an expert on the hydraulics of the braking system but that sounds like a master cylinder/brake servo issue, i.e. it doesn't bleed the pressure off after the pedal is released, could be totally wrong mind you, but if it were me that's what i'd be checking.
Old Aug 13, 2010 | 03:32 PM
gav.rst's Avatar
gav.rst
make sure caliper housing is clean where rear brake pads sit, check if u hav any kinks in ur brake pipes usuall couse check if ur wheel bearings isnt 2tight if they dnt turn freely,or bleed brake system air could be in pipes.
Old Aug 13, 2010 | 05:57 PM
cossie.087's Avatar
cossie.087
nor am i rog hopeing that it could be something more simple before i start ripping it out .
still it will be something else elimenated if not.
Old Aug 13, 2010 | 05:59 PM
cossie.087's Avatar
cossie.087
gav.rst.
no problems there.
Old Aug 14, 2010 | 08:45 PM
cossie.087's Avatar
cossie.087
changed brake servo no joy could it be anything to do with the abs system.
Old Aug 18, 2010 | 07:04 PM
cossie.087's Avatar
cossie.087
hi lads ,any body know anything about the relays for the abs system and where to find them to see if they will sort out these brakes any help welcome.
thanks cossie.087
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
