Zetec Conrod question
Old Aug 13, 2010 | 09:16 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Question Zetec Conrod question
Just a quick one. Does anyone know the difference in length between blacktop rod and silvertop?
Hopefully it'll be enough to make up the difference of pistons I'll be using...
The gudgeon pins the same diameter?
Old Aug 13, 2010 | 09:35 AM
12_Second_rst's Avatar
12_Second_rst
gudgeon pins are smaller on black top rods
and im not 100% but i think its the black top rods that are longer as i had blacktop pistons on silver top rods before and the piston came about 3mm from the top of the block
i had to have my silvertop rods machined out and bronze small end bushes pressed in to take the blacktop pistons cost Ł140 to do the 4 rods the bushes where from a golf gti as they have the same pin size as the blacktop and the bush was big enough to fit into the opened out silvertop rod
Old Aug 13, 2010 | 11:27 AM
I'm sure this was covered in depth in either FF or PF mag last year, would be worth getting a copy, defo remember it had these dimensions in it.
Old Aug 13, 2010 | 01:43 PM
AstoN_B's Avatar
AstoN_B
Im positive the blacktop rods are longer, the pistons i intend to use have a greater distance between pin centre and piston crown so i need shorter rods ideally so they sit a bit lower in the block otherwise they'll protrude and comp ratio will be too high.
The silvertops small end is slightly larger isnt it? around 20mm?
i cant afford to spend tonnes on a nice shiny set of forged pistons for relatively little bhp so am trying to find a decent set of pistons similar to the 1.8 bore zetec.
the VAG 1.8 20v pistons would be brilliant as they are 81mm so the block only needs .4mm bored out, and the pistons are forged mahle. They run between 9.2 - 9.5:1 in the different specs of 20v. The pistons i've found will come with rods but i HIGHLY doubt the rods will fit the blacktop crank, if they did i could use them too since they're stronger and will be shorter due to shorter stroke of crank (86.4 vs 88)
i may have to use a de-comp plate afterall with two gaskets. Trying my best not to go this route without slowing the build down due to lack of funding.
Neil Clark
21
Oct 1, 2015 07:02 PM
Fiddy
21
Sep 29, 2015 06:10 PM
focuspower
Sep 20, 2015 03:51 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
BRAM
Sep 8, 2015 07:11 AM
