efi head
Old Aug 12, 2010 | 09:41 PM
dorrisbjanet's Avatar
dorrisbjanet
Default efi head
apart from the cut outs for injectors is a efi head the same as carb one (valve length;size etc) i am running efi head on a weber and have got a carb kent cam cv22 dont want to fit it if it is going to bend valves (car is 1600 hotrod)
Old Aug 13, 2010 | 01:39 AM
hillzy2k's Avatar
hillzy2k
i assume your using an adaptor of sorts to cover the injector ports for the carb manifold... but in in short, the valve train is identical and your cam will fit no problem.
Old Aug 13, 2010 | 08:48 AM
dorrisbjanet
yes i am using modified manifold just wanted to check as they list a different number cam for efi & carb . will put it in today now as i am racing tomorrow thanks mate
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
dms04
Sep 11, 2015 01:57 PM
