Engine swap??
Old Aug 12, 2010 | 06:46 PM
j99ens's Avatar
j99ens
Default Engine swap??
I have a 1.8 zetec and was thinking about putting a 2.0l zetec in as there so cheap
My 1.8 is 115 brake and the 2.0l is 130 brake.
I it worth doing anything to mind like a remap. Would i gain 15 more brake from the remap??
What do you think??
Old Aug 12, 2010 | 07:13 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Depends what you're looking at achieving, if you want big power then i'd say drop the 2.0ltr in. 1.8's aren't exactly slow as i guess you've gathered, so yeah a Remap would work well. Exhaust system and uprated airfilter/induction kit would release a few more ponies, 10-15 in most cases. Then after that, if you're not wanting the 2.0ltr you could either use some Webber 40 carbs, or even have a word with Jenvey about some throttle bodies, they'll put you up to a good 180-190bhp, maybe more depending what ECU you use, PLUS few things sound as good as a zetec on throttle bodies at full chat.
Hoep this helps a bit.
Old Aug 12, 2010 | 07:59 PM
j99ens's Avatar
j99ens
My thinking is put the 2.0l in because i not got alot of money but want it to be a bit quicker, well feel quicker anyway.
I have a focus estate so exhaust arent cheap for it.
I have a k&n pannel in it now with the airbox.
Old Aug 23, 2010 | 10:49 PM
blackbeautyzetec's Avatar
blackbeautyzetec
i have a good engine if your interested mate.
80,000 cambelt changed at 78,000
everything comes with it minus th box as i needed that.
Ł200
Old Aug 24, 2010 | 01:53 AM
focusrrx87's Avatar
focusrrx87
it's not a case of just putting a 2.0l in you need the gearbox drive shafts gear linkage and tower, the ecu ect ect...
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
