Problem neighbour question regarding fence
If a fence is deemed as OURS, and a neighbour from the other side of the fence removes a support bracket, would that be grounds for defacing property or whatever you want to call it? as i said the fence is ours and is actually on our land, not his.
Can you clarify how it's actually on your property, have you checked the deeds? I imagine in would be covered under some sort of vandalism/criminal damage, but you need to be able to prove he did it.
he did it because hes got nothing better to do than annoy and medal with other people. And any case why remove the support bracket anyway?
and also forgot to mention he chucked the metal bracket on my driveway...................... i really could knock him out but i will not do him the honour of seeing me being taken away in a cop car etc.
if its just a support bracket then dont worry bout it ! it might of been rotten and he's going to replace it. if your looking down your garden from your house you are responsible for the left hand side only it should be in your deeds.
look at the party wall act to pal
Will check out what we need to yeah
Sounds like a dick, but unless you actually saw him do it, then there's not alot you can do. Perhaps if you went to his house and asked him if he saw anything or anyone, and give him the chance to admit it, if he's a twat then i'd report him, not that they will do anything but it might be a deterrent in future.
Proper nosey twat, he needs to get his own life
Sounds exactly like a problem that's happening to someone else I know, they had the same issue with a fence that fell down, guy A) Approaches neighbour and asks about mutual costs to fix fence, he says "F*ck off", so guy A) gets fence repaired, then neighbour complains to police etc and sloictors are involved saying it's substandard blah blah blah, so he ripped it down and left it a mess, then built one further back in his own garden and left the guy with the mess.
Sweet! TBH that kinda sounds like what's happened with you seeing as you have a fence in your own garden.
Doesn't sound like you'll get anywhere without hassle, personally i'd just go round and tell him to mind his own fcuking business and that'll be then end of it as far as your concerned.
Sweet! TBH that kinda sounds like what's happened with you seeing as you have a fence in your own garden. Doesn't sound like you'll get anywhere without hassle, personally i'd just go round and tell him to mind his own fcuking business and that'll be then end of it as far as your concerned.
andrewmctiernan
Sep 8, 2015 03:05 PM
