cant strip a T3 turbo
Old Aug 12, 2010 | 02:00 PM
john_d's Avatar
john_d
Default cant strip a T3 turbo
cards on table.
i've never touched a turbo until 11:30 today
i bought a manifold that came with a T3 stage 2 (apparently), not bad for £20
as its needing rebuilt, i thought i'd strip it if i break it it doesnt matter as i really only wanted the manifold at this time.
so, no matter how try to do it, there is always something stopping the bolts coming off, here are some pics
i can remove the compressor housing, thats it, the rest of it is like somethingfrom the krypton factor!
anyone offer any advice?
Old Aug 12, 2010 | 02:24 PM
dearing5's Avatar
dearing5
slacken all the housing bolts and twist the centre housing...that way the bolts will move out the way of the feed/return
Old Aug 12, 2010 | 02:25 PM
Al3dr's Avatar
Al3dr
Hi,
Give it a good dose of wd40 around the exhaust housing, and a few clouts with a soft hammer. Then rotate the exhaust housing in both directions until you can withdraw the bolts.
Old Aug 12, 2010 | 03:06 PM
john_d's Avatar
john_d
failed, it aint budging and i gave it more than a few "soft" taps
Old Aug 12, 2010 | 08:49 PM
Alvyn's Avatar
Alvyn
put a mark-line on the 3 parts so that it all stays in the right position for when you put it all back 1st! now as said slacken all the bolts and leave to soak over night in a tumb of diesil and wack it as said with a soft mallet!it will twist
Old Aug 12, 2010 | 08:55 PM
dearing5's Avatar
dearing5
it will go mate lol i had the same thing...just need to keep whacking it until it budges.
and yes dont forget to mark all the shafts etc unless your getting it professionally balanced....prob best to anyway.
Old Aug 13, 2010 | 03:07 AM
hillzy2k's Avatar
hillzy2k
failing that, a bit of blowtorch action on the housing may help slacken it. but itl go eventually.
Old Aug 13, 2010 | 09:10 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
I ended up clamping mine solid in vice and battering the housing to get it of the bearing/body. Soaked in combination of wd40 and plusgas (much better but didn't work)
Tried heating up too. Eventually came off after knocking a couple chunks out. Which is fine since it was cracked most of way through in about 7 places!
Old Aug 13, 2010 | 03:18 PM
john_d's Avatar
john_d
well i have used all the wd i have and this fucker aint moving, went to my dad's, popped in his heavy duty vice and whacked away but neither of us could remove it!
as i said it was needing rebuilt and was cheap but its to the point in take the grinder to the fucker and just buy another!
excuse the language.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
gavt123
Sep 5, 2015 10:03 AM
kevin36
Sep 2, 2015 06:24 PM
