Anyone running a 3dr with the last style Sapphire dash?
Old Aug 10, 2010 | 09:45 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Anyone running a 3dr with the last style Sapphire dash?
As title, what does it look like?
Old Aug 10, 2010 | 10:09 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
just like a late spec sapphire dash i would imagine,lol.
it should all fit but the steering colum cowling is different,as its for the adjustable colum,aka 4x4.so there may be issues fitting it.
i have a late spec dash if you want to do a trial fitting.
Old Aug 10, 2010 | 10:29 PM
Iain Mac's Avatar
Iain Mac
Here's my XR4i
Old Aug 11, 2010 | 04:22 PM
Martin-Hadland
Originally Posted by Iain Mac
Here's my XR4i
Is that a Raven dash? What I'd like to see is a grey dash with the RS ecu cover in place against 3dr seats.... I guess I will know soon enough anyway
Old Aug 11, 2010 | 04:40 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Can you get the hooded dash in grey Martin?
Steve
Old Aug 11, 2010 | 04:58 PM
Cossy Mike's Avatar
Cossy Mike
There's a girl in our group done this to her 3-door, looks okay until you stand and look properly then it looks a bit out of place.
Saying that she has leather trim out of a saph as well.
Old Aug 11, 2010 | 05:05 PM
Martin-Hadland
Steve
Yes, I have two of them.. They were fitted to K plate Sierra's
Old Aug 11, 2010 | 05:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you need to fit it, make sure you get every little screw and bit of trim and ecu bracket, the works
there is just enough give in the looms to move everythign about as you gain the passenger cubby hole if oyu do it right, i was never a fan of puttin gthe ecu's there as they were a right pain in the arse to get out, but with the glovebox out they are much easier
also need to use the later a piller trims and plastic kick panels in the footwells and you'll lose the speakers in the lwoer dash
as for the column, the later ones are adjustable, and it's simply a case of removeing the new column and putting it into the 3 door
the only place you are going ot have issues is with the stalks for the washers/wipers as the 3 doors have buttons on the dash whereas the rest of the cars have them in the column stalks
you can still fit the centre door opening and lights out stuff into the later dash with a bit of fiddling
you also need to use the later spec heater controls, them 3 screws just need to come out and everythign comes out with it, just unclip it form the heater box and job done
one more thing, the surround is clipped in on the left of the heater vents, so you need to be very careful pulling it out as once it's broken it's going to need a bit of fixing to stop it from rattling like a kid with a new rattle when you are driving along
it's an easy job when you've got a donor car to strip the bits from
Old Aug 11, 2010 | 05:22 PM
Martin-Hadland
Dojj,
All that is correct other than the column bolting directly in, it doesn't as the top support is smaller on the 3dr where the tube runs through and won't bolt up... This can be modified though
I'm running the later stalks, adj column, later switchs and the ecu's will be located as per the later car
Old Aug 11, 2010 | 05:23 PM
Iain Mac's Avatar
Iain Mac
Raven dash from a J Reg XR4x4 - I've kept the door trims and kick panels from the XR4i but there is a wee gap just visible at the top of the passenger side one - some day, I'll do something about it.
Old Aug 11, 2010 | 05:31 PM
dojj's Avatar
dojj
Dojj,
Wasn't aware of that martin, is this due to the earlier cars not having that deformable section surruonding the column then?
And are you going the whole hog and getting 92 spec door cards as well? They did them on the lhd cars right up to the end of the sierras production so someone will have all the innards to make it a seamless transition
Old Aug 11, 2010 | 05:47 PM
Martin-Hadland
If someone has the lhd late door cards then I'm a buyer......
Old Aug 11, 2010 | 06:10 PM
Iain Mac's Avatar
Iain Mac
My column bolted straight in?
The shell was new in 1985 so has the later door latches.
Old Aug 11, 2010 | 06:19 PM
Martin-Hadland
Did the collapsible section fit then? My bracket was 6mm too small to accept it.
Old Aug 11, 2010 | 07:12 PM
Iain Mac's Avatar
Iain Mac
Yes. The only problem I had was, having fitted the brace for the column, when it came time to fit the clocks the speedo cable fouled so I took the bracket off.
Old Aug 11, 2010 | 07:17 PM
m4tt274's Avatar
m4tt274
i used escort steering column surrounds and stalks on the the p100 as i dont have the adjustable column.
its a crummy phone pic but you get the idea
Old Aug 11, 2010 | 07:25 PM
Iain Mac's Avatar
Iain Mac
I do like that but couldn't even begin to figure out the wiring to make the "wrong" stalks work!
Old Aug 11, 2010 | 08:59 PM
dojj's Avatar
dojj
i shall make some enquiries
Old Aug 11, 2010 | 09:19 PM
Martin-Hadland
Cheers Dojj I would buy the whole car if needs be and just sell it on or break it.
Old Aug 11, 2010 | 09:28 PM
Moonstone Steve.
[center]
Cool, they do look so much better with a modern feel and look rather than the square looking old dash.
Steve
Old Aug 11, 2010 | 09:34 PM
dojj's Avatar
dojj
they are fairly common on the continent, mainly spanish types bought them and they can be had for not a lot of money, comparable to a uk late spec sierra
i'm just trying to find the website that i was shown a while back which reams and reams of cars for sale, much like the uk version of the loot, free ads type paper, but on the internet as someone had bought a car form there
i'll let you know as soon as i get an answer or find the ad
you could always ask ryan3 if there are any in malta, there seems to be a roaring trade in selling all their fords to us brits
Old Aug 11, 2010 | 09:35 PM
Martin-Hadland
Steve
Agreed I'm picking all the best bits and using them all.
Old Aug 11, 2010 | 09:37 PM
Martin-Hadland
Last time I saw one for sale was in Portugal and it was very expensive.
Old Aug 11, 2010 | 09:39 PM
J1mbo's Avatar
J1mbo
B1mbo
ahhh noooo martin !
Old Aug 11, 2010 | 09:42 PM
Martin-Hadland
Originally Posted by J1mbo
ahhh noooo martin !
hahahaha My Sierra will be exactly that... Mine! I'm building it for me and thats the only person I have to please (ok maybe the wife too!) but I guarantee you it will be the best 3dr out there to drive!
Old Aug 11, 2010 | 09:53 PM
J1mbo's Avatar
J1mbo
B1mbo
yeah i bet it will be but it will forever have the wrong dash
it just dosnt suit the rest of the car everything is sooo square
saying this when its done im sure it'll grow on me !
Old Aug 11, 2010 | 10:07 PM
Moonstone Steve.
Jim you only need to look at the pics above and you know its just so much better/nice to look at a live with really.
Steve
Old Aug 11, 2010 | 10:14 PM
m4tt274's Avatar
m4tt274
the facelift dash or later dash, whatever you wanna call it, is soo much better looking good effort for building 'your' car how you want it
Old Aug 11, 2010 | 10:15 PM
Martin-Hadland
Its going to have soooooo many wrong parts that a dash isn't going to make any odds I'm keeping all the old shit anyway.
Old Aug 11, 2010 | 10:18 PM
J1mbo's Avatar
J1mbo
B1mbo
Steve
i must be old fashioned or something id go with what the car had originally
i love a modified outside, martins black with silver monte's will look the nuts but inside is a different story
i guess your right with it being easier to live with
i think seeing it with a different colour surround would be good
Old Aug 11, 2010 | 10:20 PM
J1mbo's Avatar
J1mbo
B1mbo
ok ok i reserve judgement till i see lol !
now martoon finger ! out
Old Aug 11, 2010 | 10:21 PM
Moonstone Steve.
Good lad, you know it makes sense lol.
Steve
Old Aug 11, 2010 | 11:11 PM
james kiely's Avatar
james kiely
well martin it certainly wont rattle as much as the 3dr or early saff dash ,it drives me nuts all the squeaking and rattling
Old Aug 12, 2010 | 04:49 PM
R4N SS's Avatar
R4N SS
am i the only one who dont like the later dash's?
Old Aug 12, 2010 | 04:50 PM
Cossy Mike's Avatar
Cossy Mike
+1
Old Aug 12, 2010 | 04:58 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
james kiely
i still prefer the early type
Old Aug 12, 2010 | 05:11 PM
xr4x4rs's Avatar
xr4x4rs
i prefer the later style if im honest but i have always ran early ones so i can have some heater vent gauges, as the later one you have to chop about and bond the mounts in
later one also looks more modern aswell
and adjustable coloums wont bolt straght in, i just converted my 88 xr4x4 to adjustable coloum and had to modify the steering coloum mount moles so the coloumn would clear as its wider and obvioulsy moves up and down, but its a simple job to fit and a nice touch i think
Old Aug 12, 2010 | 08:57 PM
Iain Mac's Avatar
Iain Mac
Mine did.
Old Aug 12, 2010 | 09:11 PM
xr4x4rs's Avatar
xr4x4rs
i dont see how it did, if it did i bet it rubs like hell if not id be very surprised unless the xr4i uses a different coloum mount
