secs monitor readings
Old Aug 10, 2010 | 08:48 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default secs monitor readings
hi
ive got a 2wd saff cos that is fitted with a secs monitor and every now and then i get some random info flashing up on the screen saying that the temps top high and map faulty this is mainly after some hard right foot driving.
all sensors and map have been changed, but still the same
dash temp gauge just sits above half way
what can be causing this?
any help would be great
cheers
mark
Old Aug 10, 2010 | 09:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Could be the sensor plugs m8,my map sensor plug was faulty and caused an alarm on the secs monitor now and again.
Old Aug 10, 2010 | 09:18 PM
MARKYMARKONE
ok i will take a look at the connectors, but im sure there a good tight fit
cheers
mark
Old Aug 10, 2010 | 09:26 PM
SS1's Avatar
SS1
Check the connection at the back of the lcd screen
Mine kept throwing up random errors, had a chat with simon
Just simply unpluging and pluging the lead back in solved the errors
Old Aug 10, 2010 | 10:48 PM
MARKYMARKONE
avid-fan
that could be the problem as who ever fitted it has left bugger all wire betwen the screen and ecu connector.
have you got contact details for simon, so i can try and get a longer lead
cheers
mark
Old Aug 10, 2010 | 11:33 PM
SS1's Avatar
SS1
Originally Posted by MARKYMARKONE
avid-fan
cheers
mark
Longer leads are not avalible matey
It's just a case of fingers cut to fuck doing the job
But a tight fit to insert back in
Old Aug 11, 2010 | 06:48 PM
bad boy rs's Avatar
bad boy rs
mine did the same recently then it packed up mate so thinks its a sign its going to die
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
pabloXR
Sep 21, 2015 12:42 PM
