Brand new built YB engine never run good spec
Old Aug 10, 2010 | 08:05 PM
bigbill's Avatar
bigbill
Default Brand new built YB engine never run good spec
completely rebuilt 205 2wd cossy engine built to be 450 bhp
all engineering work carried out by CTM north london
all parts acid cleaned and painted where neccessary
rebored plus .40 block and light resurface to deck
lightened and balanced cossy rods
lightened and balanced crank and flywheel (resurfaced) fitted with new arp bolts
new 8:1 comp woosner pistons
new high pressure oil pump
new mains big ends and thrust bearings all vandervell/cossy
crank reground plus .25
new arp stud and nut conversion and metal head gasket first light skim to mint head
head presure and crack tested reground valves new stem seals and hydrolic tappets
BD14 inlet and BD10 ex cams mint cond with new verniers and burton race belt and tensioner
new alternator with alloy v belt pulley, same on new waterpump, REYLAND bottom pulley and new crank cam belt cog
all new sensors, cps ,dissy pick up ,tps rotar cap leads plugs etc
joe stevens big wing baffled sump moded to fit mk.2 WCX member (will still work in cossy),carbon aero quip breather system and oil seperator
new ht racing swedish plenum (to be fitted)
have got 2wd or 4wd exhaust manifold
NO TURBO INJECTORS LOOM OR ECU
was going gt30 660 siemens and motec
this engine has a full photoghraphic rebuild to the highest standards by t craig ltd and has cost well over 4.5 k
£3500.00 ono
Contact Iain on 0035387 8170345 or 01883 744179
Engine is located at RH9 8BA
Old Aug 10, 2010 | 08:43 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
sounds good that bit of a bargain considering its brand new good luck
Old Aug 12, 2010 | 09:58 AM
bigbill's Avatar
bigbill
SOLD
JoeyBoyden
Jan 4, 2024 02:36 PM
markk
Dec 2, 2021 06:59 PM
RsS2daz
Aug 14, 2015 05:26 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Zoggon
Aug 10, 2015 10:39 AM
