complete s2 breaking,loads and loads of new uprated parts
today i stripped the turbo as it was smoking and expected it to just need new seals,well the housing is split and it has in and out play,i have spent far too much on it not to mention the time restoring it.if no-one takes the shell im going to crush it with a bulldozer for all the hassle i went through welding it up.all parts are plus postage,some parts will be ready to be sent off tomorrow.
new konis and spax -40mm springs,done 200 miles,1 of the adjusters on 1 front strut is broken.struts are out of warranty but were new in their box when i got them,£280
cossie rear disc conversion,calipers,discs,hubs,handbrake cable,ready to bolt on.new discs and ferodo pads have done 70 miles,£140
cosworth front calipers and 2wd discs,brand new last week,discs and ferodo pads have done 70 miles,£150
turbosystems chipped s1 ecu and superchilled fuel ecu,working at 14 psi,transformed my car,£120
full car polybush kit,powerflex kit so not that other crap,done 200 miles,£100
new fuel pump in powdercoated cage,done 200 dry miles,£70
airtec front mount intercooler with twin fans,£140
rs 3 spoke steering wheel with horn push and boss,very good condition,£80
braided brake hoses,£20
new steering rack with new track rod ends,£35
5 wheels,painted recently with nearly new toyo proxes,£140
very clean interior,90 spec,no rips,new drivers bolster foam,no sagging doorcards or holes,1 small fagburn on drivers squab,£200
dash binnacle with boost gauge where fuel computer would be,all moulded in so looks factory,comes with white faced boost gauge,£40
number plate,g500 esc.valued at £200offers
bonnet,no dents or rust,£50
doors,drivers door is mint,pass door has a couple of small dents,£40 and £30
front bumper,modified 90 spec,bottom bar cut out and filled,rear of middle bar cut out for max air into the cooler,car runs loads cooler with this removed.£100
rear bumper,£30
kit,uncut,all jacking covers there,£45
engine,freshened up 47k ago,runs sweet,new followers,water pump and spark plugs,£250
lsd gearbox,no crunching or whining,£100
loom,no dodgy alarms,stereos etc,£70
headlights,indicators and side repeaters,all new pattern parts.£40
lock set,all works off 1 key,spare inc.new petrol cap and new barrel as was seized.£50
rear arms and arb,fuel tank strap,arb brackets(new),all just been powdercoated black,£80
magnex stainless 4" exhaust with front flexi.good burble on idle,£70
roose silver boost hoses,4 of.£35
all other parts available as the car was running up till today,was only moted last month and taxed last week.sick of it now and want something newer.would sell whole car but you see what im asking for all the parts above.to make the car mint it needs the roof filled and painted,pass door and wing painted,a turbo,thats it.but i have spent too much on it and at 31 m maybe a bit old for a s2.i enjoyed collecting all the parts for it,welding it etc but i have just had enough of it now.
p.m me,collection is preferred,postage is available on everything but is extra.cheeRS,lee
rear bumper,£30
incase you missed the 1st line of my ad,yes i have the turbo,condition is category 1 fucked,split turbine housing,in and out/side to side movement,chunk missing from water jacket,its currently in bits on my garage floor and thats why im breaking the whole car.if you want it ill send you it.it does have a good turbo technics badge though!
what make is the fuel pump please mate and does the carrier come with all the plate to mount to car? If you could maybe grab us a pic that would be great. Dont suppose your drivers side door seal was any good was it? Mines split along the bottom. Cheers, mike
cant remember the make but its 2 months old,never seen rain and has done 200 miles,the full cage was shot blasted and powdercoated gloss black,what seals do you need?the door frame to door or the lower window seal?my window seals are brand new,1 is still in its bag and the big door seals are mint too.
Turbocharging Technician
i understand you having a prob with the cracked housing, but what is wrong with the "in and out play" on your turbo if its getting re built with new bearings and thrust washer and disc? thats the whole poiont of the re build, to sort that out, the seals dont wear in so much as the shaft moves too much due to the worn bearings and oil then bypasses the seals as they cant cope with the large ammount of movement.
yeah i need the door frame to door big seal. Would u grab us a pic of fuel pump and bracket set up please. Im away on holiday this week so if u dont hear back from me again u know why as im on net with phone here and it hardly lets me get on here. I'll be bk saturday though. Cheers mate
dunno,but side to side movement doesnt get as much bad critiscism as in and out play.the turbo rebuild place on ebay said that.but the whole thing is shagged.ill text you a pic.
all the parts have been removed and are listed in the parts for sale section with good pictures.somebody asked last night about a 2 part speedo cable.i have 1.sorry,i deleted your pm.
sorry,the whole interior is sold,the handles look a bit shiney and arent the best,put it this way,if youre looking for mint then these are average.cheers,lee
hey mate, how much posted for the seals that run along the bottom of the windows along the doors?
also is there any glass going? you may not want to do away with the front screen but thats what im sfter if its heated with the blue strip??
how much for this posted too bud?
cheers, joe
cheers, joe
what condition are the interior door handles and drivers door card im after MINT 1s
