anyone good with seat leons?
Old Aug 10, 2010 | 05:08 PM
crighton13's Avatar
crighton13
Default anyone good with seat leons?
hey folk my dads car doing my box in its sparkin on all 4 but running on 3 and the injector is gettin power, it is the 3rd cylinder thats not running and i dont understand y i hread sumwhere that these engine do this after around 60000 miles? anyone got any info lol cheers folks
Old Aug 10, 2010 | 05:09 PM
rs-tuner's Avatar
rs-tuner
What engine?
Old Aug 10, 2010 | 05:10 PM
crighton13's Avatar
crighton13
its a 1600 16v a azd engine
Old Aug 10, 2010 | 05:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
coilpack being gay?
plug in vagcom or a code reader, the car will know
Old Aug 10, 2010 | 05:16 PM
crighton13's Avatar
crighton13
just replaced the coilpacks mate there fine and i did plug it in and it came up with water temp sendeor changed that and no codes now just a nightmare
Old Aug 10, 2010 | 05:23 PM
rs-tuner's Avatar
rs-tuner
Does it always run on 3 or just at tickover
Old Aug 10, 2010 | 05:46 PM
as355f1's Avatar
as355f1
unplug the air mass meter and take it for a spin, if it clears that is your problem.
Old Aug 10, 2010 | 06:02 PM
Oranoco's Avatar
Oranoco
Have heard of this on the VAG forums I use. Not 100% sure but seem to recall the ignition amplifier being a suspect.
Get VAG-com plugged in and see what that returns with
Old Aug 10, 2010 | 07:37 PM
rs-tuner's Avatar
rs-tuner
They don't have air mass meters
Take the throttle body off and give it a good clean inside.
Old Aug 10, 2010 | 07:42 PM
as355f1's Avatar
as355f1
eh, yea they do mate, just done one, they look like this
http://cgi.ebay.co.uk/SEAT-LEON-IBIZ...item2308f7e7c0
Old Aug 10, 2010 | 07:48 PM
as355f1's Avatar
as355f1
edit, you are correct just noticed its an azd engine these don't
Some 1.6 engines have a MAF sensors, engines with the Simos injection system, coded AEH, AKL certainly do. These engines have the air filter in a large box on the right (nearside) of the engine compartment and the MAF at the outlet of this airbox
Old Aug 10, 2010 | 07:50 PM
chaffe's Avatar
chaffe
Turbocharging Technician
not enough boost, disconnect the wastegate pipe and screw the actuator arm as tight as it will go.
Old Aug 10, 2010 | 08:05 PM
as355f1's Avatar
as355f1
He will have to fit a turbo first
Old Aug 10, 2010 | 09:32 PM
xrt-mart's Avatar
xrt-mart
I work for skoda so same difference if the fault is 100% only on one cylinder then that rules out sensors, air flow meters etc as there not cylinder specific. The coil on plugs do go fault on these but if you have already done these then that is that one ruled out.
I would (if you havent already) swap plugs around and see if the fault moves. If that doesnt then swap the injectors round and see if that moves it. If you have VAG com then miss-fire recognition is on measured values 15 (cyl 1-3) and 16 (cyl 4)
Got to be one of them 2 causing the fault I recon.
HTH
Mart
Old Aug 11, 2010 | 05:32 AM
chaffe's Avatar
chaffe
yeah i know lol, it was a joke.
markk
Dec 2, 2021 06:59 PM
3drRich
Sep 13, 2015 07:32 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
