Will bits from a hatchback fit a sapphire?
Old Aug 9, 2010 | 09:06 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Default Will bits from a hatchback fit a sapphire?
Hello, Its me again not knowing anything...
Will the front and rear bumper from a sierra hatchback (1.6l, F plate) fit a sapphire cosworth and look the same?
Also i need the window seals (rubber bit round the window) will they fit too? I need the front lights as well as mine have a small hole in them and everything does look like what i need but dont want to get it if they dont fit.
I am asking this as i might be able to get hold of a standard hatchback for breaking.
If none of these fit do i need them from a cosworth to look the same or can i find a standard sapphire for these bits.
Many Thanks Eigdoog
Old Aug 9, 2010 | 09:44 PM
martysmartie's Avatar
martysmartie
No front bumper is completly diffrent on both and is unique to the Cosworth as are the front grill and lights (although lesser models can be adapted by cutting the tab off) unless you mean fogs?
The rear bumper is the same as any other Sapphire but the black inset is unique to the Cosworth and isn't avaliable anymore, I seem to remember hatch and Saphs are different though.
The windows rubbers will be the same.
Martin
Old Aug 9, 2010 | 09:51 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Many Thanks
Do you know about the front lights? not the fog ones.
Thanks Eigdoog.
Old Aug 9, 2010 | 09:55 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Front lights are different but you can adapt them by cutting the plastic lugs off that the hatchback lights have. I did this on my old xr4x4 when I fitted a cossie grill and bonnet. Don't remember it being that hard to do.
Old Aug 9, 2010 | 09:57 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Fog lights are the same but they sit in a plastic surround which covers the edges on the cossie.
Old Aug 9, 2010 | 10:33 PM
martysmartie
Yes thats what I said above, the headlights are different in that the tab location is different that the grill bolts to, you can cut it though.
Martin
Old Aug 10, 2010 | 10:55 AM
I used "cut down" non cossie lights and found adding a 10mm nut under the grille retaining tabs before screwing to the headlight flange was needed to get them lined up better.
The trim can still be bought new from East Kent trim supplies, around £15 delivered from memory.
jason_nike
Aug 18, 2019 10:53 AM
markk
18
Aug 17, 2015 05:19 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
saph in dorset
Aug 14, 2015 10:10 AM
