replacing wheel bolts
Old Aug 9, 2010 | 06:58 PM
spunknik's Avatar
spunknik
Default replacing wheel bolts
Help needed, maybe a simple A:
I need to replaced my wheel bolts with longer one's as im using spacers! I have a escort gti with ABS sensor fitted. Will Bolt flange just prise off using a hub puller, have tried today using some heat but flange wont budge, Am i missing sumthing out, Any info would be a great help. I need car for work.
Cheers spunknik
Old Aug 9, 2010 | 07:00 PM
gtinutter's Avatar
gtinutter
on my escort i just hit the wheel stud and there come out from behid m8 post a pic to so we know what u mean
Old Aug 9, 2010 | 07:09 PM
spunknik's Avatar
spunknik
I Know what your saying fella, but theres no room to do that as you have the ABS sensor plate in the way?
Are have to send pic tomorrow now.
Thanks anyway.
Old Aug 13, 2010 | 03:13 AM
hillzy2k's Avatar
hillzy2k
how about removing the sensor? if you turn the hub, you should be able to tap them out. failing that its a strip down of hub job. If im correct, i believe mondeo studs are a fair bit longer btw.
YODI
Aug 30, 2015 01:12 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
borboyous
Aug 22, 2015 11:17 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Bosch
Aug 4, 2015 05:14 PM
