zetec conversion wiring
Old Aug 8, 2010 | 04:15 PM
rudkinrst's Avatar
rudkinrst
Default zetec conversion wiring
hi all i have just removed the ecu, PATS transponder and ecu loom from my mk6 escort si donor, the engine is a 1.8 115 silvertop and i have read everything i have found on the tinterweb but cant find any advice on which wires need connection to what in the multi plug that conntects to the car loom
in my multi plug i have the following
black/green
pink/yellow
white/red
white/green
white/black (tacho)
orange/yellow (ecu live?)
black/yellow (earth?)
black/blue (perm live for ecu?)
3xpurple/blue (i assume these are fuel pump?)
can anybody help me out pretty please with how to wire this into my mk3 escort.
many thanks
Old Aug 13, 2010 | 03:25 AM
hillzy2k's Avatar
hillzy2k
what are you putting it in? il dig out a wiring diagram for you.
Old Aug 13, 2010 | 03:26 AM
hillzy2k's Avatar
hillzy2k
mk3 escort, silly me, need to learn to read more. done this not long ago on mine. il update u tommorow.
Old Aug 13, 2010 | 06:57 PM
rudkinrst's Avatar
rudkinrst
hi all, im really needing help now i have the engine wiring underway but cannot get a spark! i have wired in the 12 pin plug with pins 1, 5 and 8 with ignition live and pin 7 with a permanent live. i understand the pin wiring as follows
1 12v ignition
2 switching feed to fuel pump relay
3 tacho feed
4 unused
5 12v ignition
6 oil pressure light feed
7 12v
8 12v ignition
9 unused
10 unused
11 unused
12 temp gauge feed
i did have 12v on the centre pin of the coil pack until i plugged the lambda in, but still have no spark, the engine sensors are all connected and the pats transponder is plugged in, i have not got a fuel pump connected yet but this shouldnt be an issue should it? the ecu is a SLUG and the engine was running when removed from the donor car and nothing has changed. the engine is earthed direct to the battery as are the 2 small black wires off the ecu!
please help as im pulling my hair out now! im getting desperate
cheers
TPM961
Jan 15, 2018 10:50 AM
S3an
Sep 26, 2015 11:39 PM
Chopshop85
Sep 18, 2015 06:13 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
S3an
13
Sep 13, 2015 10:01 AM
