FRS charge cooler mounts
Got some bushes to replace the original cooler mounts, Does the
Charge cooler just pull off when you take off the boost pipes?
Thanks!
Thanks!
did you pay fords stupid prices for the original bush as the normal focus airbox bush works for a fraction of the cost
Hi mate, yeah I Sussed it in the end.. And it was the single one that's gone...
I got poly bushes to go in there, but fooked if I can get them in
lol. So just ended up swapping 2 around for now until I can figure out a way to press the new ones in...
just got my cooler this morning, the 3 mounts are part of a plate which unbolts from the bottom of cooler so i'll make a bracket with same holes as that. does it have to be on rubber mounts?
I was gonna mount it solid to engine/gearbox since pipework can be solid too as it'll all move together.
ill have to try and find the bracket it sits on too then as it only came with the lugs which are bolted to bottom of it. Or drill a plate out to suit.
By mounting it solid i meant bolting it to a bracket through rubber bushes anyway and mounting that bracket to engine/box. Surely that would be enough?
DavidK
Sep 27, 2015 02:55 PM
