Sill Stands
Would it be worth fitting them to my mk2 fiesta? Any advantages/ disadvantages?
Been thinking about fitting some for a while the car will be mainly used for track days etc.....
Brian
Brian
mine lift the car 22.5" off the floor and because they are to the side you never have the problem of them being in the way when working on axles/gearbox/zorst engine etc,
also they are garaunteed not to slip like an axle stand on an axle or chassis leg,
only dissadvantage i can see is that you need a jack with a minimum lift of 700mm so the cheapest jack is a 45kg sealey at Ł150
make sure you run the tube through fully from outer to inner sill and reinforce it on both sides or it will buckle under weight, the stands will most likely come with the kit or just buy the fitting kit and weld your own stands up as they are not cheap at Ł280 for stands and fitting kit,
but well worth it
ignore the crappy axle stand
it was holding the gearbox in place while making the gearbox mount.
Cheers Marc
It was seeing your's that started me off about getting some for my Fiesta
Do you have any pictures of the tube from inside the car (if that makes sense?)
Cheers Brian
Cheers Brian
mk3ste
Oct 17, 2021 10:09 AM
155lee
Sep 6, 2016 11:10 AM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
