decompression plates
Old Aug 7, 2010 | 06:33 AM
john_d's Avatar
john_d
Default decompression plates
does anyone know what thickness if plate would i need if i wanted to build a 2litre zetec turbo?
i know some concider a plate cheating bbut hey-ho
Old Aug 7, 2010 | 11:19 AM
JonathanJ's Avatar
JonathanJ
That all depend on how much boost you going to go for , as you are going decompression plate would think you going for a low boost situation , and it also depends on if you going to fit 2 head gaskets ( one either side of plate ) or do the other ( not very nice ) and fit only one between plate and head .
I would think you just need to have a look around and see whats available , but would think that 2mm would be around the figure required
Old Aug 7, 2010 | 03:12 PM
Sp3no's Avatar
Sp3no
A decompression plate is THE worst way to lower compression, new pistons and rods are the way to go if you want it to last. A decompression plate will double the risk of headgasket faliure. You can fit C20LET pistons if you are on a budget but they need slight modification
Old Aug 7, 2010 | 06:23 PM
john_d's Avatar
john_d
sorry but i dont have £500 or what ever they cost.
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
