Which actuator on a stg 3 MSD ALS chip?
Old Aug 6, 2010 | 11:18 PM
Mr C's Avatar
Mr C
Default Which actuator on a stg 3 MSD ALS chip?
I have a stg 3. 330BHP 2wd sapphire using a 500 cooler, 803s and a T34 .63 Mar- m 247 shaft, which actuator would I be best to use in this, the car drives best around 5-7200 RPM limiter and I like power to be consistent, ideally the same power lower down to match the top end, so am I best off with a -34 or -31 actuator to achieve consistent power?
What do you run? I will be mostly on track and drifting
Old Aug 7, 2010 | 06:48 AM
KSA-Cossie's Avatar
KSA-Cossie
-34 on mine m8.
Old Aug 7, 2010 | 07:06 PM
Mr C's Avatar
Mr C
Thankyou, how does the power come in and I'm guessing it holds the boost well at that?
Anybody else using an actuator?
Old Aug 7, 2010 | 07:11 PM
LHD220Turbo's Avatar
LHD220Turbo
personally i'd ditch the greens and get greys or siemens blacks with a new chip; see 380-400hp with that spec, might as well get the most out of it
incidentally i had -31 actuator on mine
Old Aug 7, 2010 | 07:22 PM
graham c's Avatar
graham c
yep am going blacks woz at msd talking to kenny yesterday
Old Aug 7, 2010 | 09:39 PM
Mr C's Avatar
Mr C
Ok blacks on my shopping list, can my existing chip run them or be re written? How does the -31 differ in use from a -34 please if both have been used they both must work but what's the difference in power delivery etc?
Old Aug 7, 2010 | 10:37 PM
LHD220Turbo
you'll need a new chip if you want to use new injectors, but if you havent got the money at the mo, greens will be ok - you just wont get the best out of the turbo
the difference between the 2 actuators is the lift pressure, 8 psi for -31 and 14 psi for -34
heres a good article https://passionford.com/forum/techni...ifference.html
Old Aug 8, 2010 | 02:04 AM
graham c's Avatar
graham c
am going to run air to airs as well
Old Aug 8, 2010 | 07:04 PM
Mr C's Avatar
Mr C
Brilliant thanks, a -34 then and I'm eventually having air injector and blacks to match, what are the part numbers for siemens injectors for upto 380 bhp as mentioned above? That lot will be plenty for a STD box etc
Old Aug 8, 2010 | 07:06 PM
LHD220Turbo
3102 is siemens blacks 55lb
Old Aug 8, 2010 | 08:11 PM
MAD Ade's Avatar
MAD Ade
Why not ask Stu at MSD?
Old Aug 9, 2010 | 05:41 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
had both and i like my car much better on a -31
Old Aug 9, 2010 | 06:12 AM
Dingy's Avatar
Dingy
Always ran a -34 on the t34 LOL
Pete ure a gay boy thats why u like a -31 - nice slow progression on entry
Old Aug 10, 2010 | 03:26 PM
pete mcrash
....stevie babes ur getting me horned up.....
JK12
33
Apr 26, 2021 12:09 PM
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
RSmark84
Sep 13, 2015 01:29 PM
