Pro's and Con's of ABS on a ERST?
Old Aug 6, 2010 | 07:36 PM
Big-Dan's Avatar
Big-Dan
Default Pro's and Con's of ABS on a ERST?
My brake calipers are away at Bigg Red being rebuilt because they were piss poor at my cars most recent MOT, I told my mechanic this and he said that the main reason why my brakes are shit is because the calipers are off a Saff (4 pot) and not standard ERST ones, he reckons the ABS pump isn't strong enough to operate the Saff calipers correctly. Is what he's saying right, should I be looking to upgrade my ABS pump to a Saff pump?
Also, I've heard alot of people say it's best to disable the ABS system on ERST's..
What are the Pro's and Con's of having the system fitted?
I (will) use it on road daily, never on track..
Big-Dan.
Old Aug 6, 2010 | 07:51 PM
djmillsy's Avatar
djmillsy
Fife Radge
the escort A.B.S is shite remove it its pish and as for the saff thing ive never heard of that the abs is belt driven anyway ive got saff disks all round on mine and have no probs
Old Aug 6, 2010 | 08:03 PM
stephenbatey's Avatar
stephenbatey
Pro's = none
Con's = it's shit and heavy as fuck
Ditch it!
Old Aug 6, 2010 | 08:29 PM
Big-Dan's Avatar
Big-Dan
Okay thanks.
Will I notice an increase in stopping power once it's been taken off?
Big-Dan.
Old Aug 6, 2010 | 08:52 PM
xr4x4rs's Avatar
xr4x4rs
the abs is mechanical on erst and only does the front brakes, there are beelts off the drivehsafts that control it and operate it and they usually snap or stretch
remove the shit and the master cylinder is fine for the cossie brakes, you wont fit a sierra one
Old Aug 7, 2010 | 12:02 AM
rstdave's Avatar
rstdave
As above mate, not much cop on rst's so i'd rip it out completely if i were you
Old Aug 7, 2010 | 12:17 AM
vaughant's Avatar
vaughant
Sierra and escort abs are totally different,electronic on saff,mechanical on erst your mates talking bollox.it's pips to take off an erst and makes a box/clutch change easier too.If your pedals shite on the Cossie 4 pots I'd suggest maybe their not bled right.
Old Aug 7, 2010 | 12:26 AM
andy130's Avatar
andy130
there crap same as frst, i ditch mine, my brakes were far better
Old Aug 7, 2010 | 12:43 AM
EIL132's Avatar
EIL132
Originally Posted by bateyovhebburn
Pro's = none
Ditch it!
It is utter shite, but how is it heavy as fuck? It's a belt driven by the drive shaft and modulator which most people leave on and just cut the belt? Mine lost more weight through rust
Old Aug 7, 2010 | 06:32 AM
stephenbatey
Take a modulator off and feel the weight of it
Old Aug 7, 2010 | 07:09 AM
Oranoco's Avatar
Oranoco
The modulators are heavy as fuck and I doubt anybody is actually that retarded to just cut the belts and think that's correct. The system is utter crap, simply doesn't work very well and gives a vague pedal feel.
You're mechanic is trying to sound clever but is talkin utter crap.
Old Aug 7, 2010 | 07:41 AM
dojj's Avatar
dojj
Resident Wrestling Legend
go and find an escort rst master cylinder and servo, replace the fiesta one with this
the escort one is used to push bigger calipers than the fiesta one so will have a larger bore to push more fluid around the system
the cossie 4 pots need more fluid in them to work the same otherwise youhave a longer pedal
just make sure you uprate the rears at the same time as you will notice the difference if your car starts to swap ends every time otyu press the pedal
Old Aug 7, 2010 | 09:10 AM
Shings's Avatar
Shings
First things first.
Get a new mechanic - he knows fuck all.
Are your calipers 2 or 4wd calipers - if 2wd that will expalain the vague pedal feel and travel due to the fact they're rigid calipers and not floating like 4wd. This is because they dont need to be floating on a 2wd.
You can remove the ABS very simply if you have the correct brake line making tool and pipe - you dont even need to remove the ABS mechanism - but you will need to short the circuit or the light will come on and fail your MOT.
But back to the original question.
The ABS on your RST is unlikely to work anyway and to getting it to work is unlikely - look in a haynes manual to understand why.
So bin it.
The cons are that if you're a shit young driver you'll go straight up someones arse at the first sign of trouble - but then it prob didn't work in the first place anyways.
J
Old Aug 7, 2010 | 09:20 AM
Chris69's Avatar
Chris69
just bin it, the whole lot is a waste of space and quite easy to remove- the brakes become more responsive and stronger- you will notice it.
Old Aug 7, 2010 | 07:01 PM
Big-Dan's Avatar
Big-Dan
Cheers for the info lads, looks like I need to get it whipped off then, majority decision
Big-Dan.
Mc5506
Oct 5, 2015 09:57 PM
