Fan problems
Old Aug 6, 2010 | 05:16 PM
HarperMin's Avatar
HarperMin
Default Fan problems
My dads got a ST170 and hes got a couple problems thats come up.
The fan speed control only seems to work on no.4, 1 2 and 3 dont work. Just a fault with the dial or something more complex maybe?
And also one of the wing mirrors has a cracked mirror. Is it just a simple part to replace seen as its heated?
Old Aug 6, 2010 | 05:44 PM
Alvyn's Avatar
Alvyn
the heater control is more than like the reostat knackered and the mirror you can replace the glass on that I believe!
Old Aug 6, 2010 | 09:43 PM
martysmartie's Avatar
martysmartie
The resistor pack needs replacing, it's a module that is behind the dashboard.
Mirror is removed same as any other mirror and would imagine theres a connector on the wiring that can be disconnected.
Martin
Old Aug 7, 2010 | 02:37 PM
HarperMin's Avatar
HarperMin
so would the resistor pack allow the heaters to work on only setting 4?
Old Aug 7, 2010 | 03:09 PM
Alvyn's Avatar
Alvyn
yep or sometimes number 1 and 4!
Old Aug 7, 2010 | 03:58 PM
martysmartie
Yes thats exactly what it does.
Martin
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
