ST170 Accelerater stuck open !
Old Aug 4, 2010 | 08:02 AM
FOCUSTARD PIE's Avatar
FOCUSTARD PIE
Default ST170 Accelerater stuck open !
Hi Guys
Last night while driving the ST170 home from work, when I accelerated away from the lights the throttle pedal stuck down on full throttle, it then released and seemed fine again. At the next roundabout I floored it and it stuck again !
Driving it gently throttle is fine, when I got home I gave it a couple of revs and the peddle stayed down on full revs, then released.
When the car was cold later in the evening took it for a run and all seemed fine, cant get it to stick.
I took the cable out and it seems fine.
This morning driving it to work it was fine untill the engine got hot and then started to stick again.
Should I replace the cable ?
Old Aug 4, 2010 | 08:10 AM
adam151082's Avatar
adam151082
It sounds like somthing at the throtle body end to me, does it stick open with the engine off?
Old Aug 4, 2010 | 09:09 AM
FOCUSTARD PIE
No, only sticks when engine is hot and running, I thought maybe the heat is affecting the cable, if that makes sense.
Old Aug 4, 2010 | 09:15 AM
Frenchy0204's Avatar
Frenchy0204
Get to tha choppa!
Maybe the heat could be causing the butterfly flap on the TB to expand and then stick?
Old Aug 4, 2010 | 09:33 AM
FOCUSTARD PIE
Would that keep the peddle down ?
Old Aug 4, 2010 | 09:39 AM
Frenchy0204
Get to tha choppa!
Oops! I should read posts better...
No, I doubt it would. The Cable is most likely "pulling" the flap open, so if the flap stuck, it would just bunch up the cable and not pull the pedal down, if that makes sense?
Old Aug 4, 2010 | 09:49 AM
FOCUSTARD PIE
Yep makes sense, I've ordered a new cable £63 !!!! so will try that and let you know if it works
Old Aug 4, 2010 | 10:03 AM
Frenchy0204
Get to tha choppa!
£63?! Jesus!
I hope for you it works, especially at that price!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
muz
Sep 30, 2015 08:29 AM
