Made It to Round 40 on Zombies!
holding the balcony i really think the wafler is needed but yeah if you start running then its not nice to use and more often ends up killing you rather than the zombies
its much more managable with two players though even with just 3 the amount of zombies to kill is crazy, also just takes one slip up or bad luck and its game over so quick but the challenge is laid down
what guns did you end up using btw?
Up to 25 packa punch stg an ppsh, mg , Then wat ever else! no brownings full stop, no ray guns, untill 27. No waffler full stop. you lose to many points using it.
We Normally have 100000 points eatch by 32. Then do one! ray gun esentiel 4 the dogs while running!
Wats ur tactic?
Wats ur tactic?
hold balcony for as long as poss then do one with a monkey and keep running usually
the wafler is needed if you hold the balcony as you can thin the amount of zombies nicely
aggree with the mg and ppsh though great for getting points
i do understand your tactic though will have to try it with retro, what route do you run?
balcony t/p to mainframe, wen have teleported stand the oppsite side to were you goin to run immediatly, so as soon as ive teleported i stand a fraction to the right, then you will see the zombies go to the right , then i do one to the left, through corridor, up the stairs then waite to drop down then gate on. Im running from 33, cos u will just wind ur points down.
Waffler wastes ur points, with the waffler i can get to 35 on the balcony, but one lucky hit, and ur down. so not worth the risk.
Example ppsh = 1 zombie 200 points.
Waffler = 1 zombie 60 points.
ppsh = 40 zombies 8000 points
waffler = 40 zombies 2400 points. Per round average.
I think Round 45 is in reach just! Then depends on wat box wants to do also, usually evens it way out at some course of the game.
The Youth.
Sep 30, 2015 09:59 PM
