car alarm going off
dont you hate it when your car alarm goes off for what appears no reason, not on the rs my daily run around.
the alarm just went off (00.35 ish) for what appears no reason at all its a factory fitted one so not majorly senstive been out and investergated cant see no reason why it should of gone off
so ive reset it ,bloody hate it though i can see me being up all night on gaurd lol as that is one of 3 cars needed to move to get to the rs
a few weeks ago i was having problems with my car battery draining itself due to a bad earth, and the clifford decided to go off at 4am (on a work night) because the battery was totally dead the clifford kicked in.
so i ran out in my bathrobe, half asleep, and it wouldnt turn off because the car had no power! and the car is delocked so i couldnt open it.
after about 10 minutes i managed to get in the boot and attached a car starter to the battery, and the alarm stopped.
anyone who has heard a clifford bell will know how fooking loud they are. there was alot of curtains twitching while it was going off
A trick used by some naughty people is to keep setting it off so you leave it off, just a thought.
For anyone that has de locked the car, you can alwasy hide a connector someone so you cna power it up if needed due to flat battery to get doors open etc.
I would just put the feed through my trailer socket on tow bar as the 12S is connected direct to live and earth.
My clifford alarm kept going off when I first got the car couldn't work out what it was, anyway turned out to be the microwave setting it off every time you turned the thing on lol.
Ive turned the micro sensor down now and its okay now.
.Ive turned the micro sensor down now and its okay now.
i am very aware of this trick and always goto the car to reset the alarm and not just do this from the house. it was because of that reason i was on gaurd most the night but the alarm has not done it since
so i'm keeping a eye out tonight too but it may of just been a isolated occurance
.as to the de-locked issue i always planned on putting the connector in the front bumper behind the number plate
kosienutter
31
Aug 22, 2015 09:55 AM
