sum1 please help
Old Aug 2, 2010 | 02:47 PM
decked's Avatar
decked
Default sum1 please help
im in the process of a 1.8 zetec turbo conversion into my fiesta mk5 its all in mounted but i cant seem to figure out wot flywheel and starter to use its a dohc 16v mondeo engine with a endura diesel fiesta gearbox some1 shed some light please
Old Aug 2, 2010 | 03:18 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i would use a zetec flywheel and sarter
maybe the clutch might be a differ input shaft for the endura box tho
Old Aug 2, 2010 | 03:43 PM
decked's Avatar
decked
thank u ill give it a try
Old Aug 13, 2010 | 04:01 AM
hillzy2k's Avatar
hillzy2k
you need a 1.6/1.8 mk3 fiesta/ mk5/6 escort zetec flywheel and clutch. clutch is same as escort rs turbo. this will bolt up to fiesta diesel box.
diesel or front mount zetec starter will do.
Old Aug 16, 2010 | 03:02 PM
decked's Avatar
decked
diesel starter no good gotta use a fiesta turbo flywheel an starter only combination that would work
Old Aug 17, 2010 | 05:30 AM
chaffe's Avatar
chaffe
Turbocharging Technician
or any efi xr2i/xr3i flywheel, they are all the same.
Old Aug 17, 2010 | 08:14 AM
hillzy2k's Avatar
hillzy2k
cvh flywheels have to have holes drilled out to 11mm. use a ZETEC escort5/6 or fiesta mk3 1.6/1.8 flywheel. bolts straight on. done it too many times. use fiesta diesel box, and any starter from mk1/2/3 fiesta, or mk3/4/5 escort.
Old Aug 17, 2010 | 08:16 AM
hillzy2k's Avatar
hillzy2k
sorry, correction with regards starter. you MAY need to use the mk5 fez diesel starter.
Old Aug 17, 2010 | 08:54 AM
chaffe's Avatar
chaffe
i think the starter and flywheel problem has been solved as the car is now nearly running
Old Aug 17, 2010 | 11:54 AM
decked's Avatar
decked
how do i upload pics i can upload a pic of the lash that is the wiring lol
Old Aug 17, 2010 | 12:13 PM
chaffe's Avatar
chaffe
i used photobucket mate, was a headfuck until i sussed it
xr2.0zetecturbo.
May 21, 2006 08:55 PM
Jim Galbally
Oct 1, 2005 07:42 PM
Jim Galbally
Oct 21, 2004 03:15 PM
Bread
Sep 28, 2004 09:00 PM
Milko
Aug 1, 2004 08:48 PM
