Cannot find topic with difference between red and green top?
Old Jan 20, 2005 | 08:49 PM
tkrath's Avatar
tkrath
Default Cannot find topic with difference between red and green top?
Hi,
I cannot find the topic re. the difference between the red top (2wd) and green top (4wd) Sierra Cosworth? Can you please help me? I've tried the "search" but cannot find it
Thomas
Old Jan 20, 2005 | 10:44 PM
nicksaph's Avatar
nicksaph
hello mate
some 4x4 had a red top, basically only real difference is the green top had a cat and all the accoiated engine manegment i.e. lambda sensor in the exhaust, different ecu.
the 2wd and 4x4 are totally different
block, sump, head,pistons,inlet and exhaust manifolds, and the list goes on, but most thing are interchangeable as far as i am aware(with some modifications),
hope this helps
RegardS nick
Old Jan 21, 2005 | 01:57 PM
tkrath's Avatar
tkrath
Originally Posted by nicksaph
hello mate
hope this helps
RegardS nick
Jep I know, but there was a topic in which a complete list was posted.
Old Jan 23, 2005 | 11:30 PM
BOBXR4X4's Avatar
BOBXR4X4
thought red top orig only run on leaded fuel ,green top unleaded plus did they do blue top? not sure so stand to be corrected.
Old Jan 24, 2005 | 05:09 PM
nicksaph's Avatar
nicksaph
that is correct mate and the blue top was escort big turbo, which also is unleaded only.
Old Jan 24, 2005 | 07:43 PM
Sheldy's Avatar
Sheldy
But dont the red top 4x4's run on unleaded as well?
I hope so cos that's what i've been putting in it!!!
Old Jan 24, 2005 | 08:20 PM
nicksaph's Avatar
nicksaph
yes all red tops can run on unleaded as long as octane rating is higher than 95 i.e. super, optimax ,etc. the only reason green and blue tops can't use leaded is it "poisons the oxygen sensor and cat"
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
Ben26
Aug 11, 2015 04:19 PM
