sierra cosworth abs
Old Jul 29, 2010 | 08:37 PM
johnyjn's Avatar
johnyjn
Default sierra cosworth abs
Does anybody know if there is any difference between a 3dr abs ecu and a 2wd saff abs ecu . If so what.Many thanks all.
Old Jul 31, 2010 | 11:50 AM
johnyjn's Avatar
johnyjn
Also need some wiring diagram with pin numbers for the abs.Many thanks
Old Jul 31, 2010 | 04:21 PM
I think but by no means sure the wiring diagram can be got from the turbosport site, the abs ecu is a different part number, but essentially the same right down to the wiring.
Old Jul 31, 2010 | 04:29 PM
martysmartie's Avatar
martysmartie
I am 99.9% sure it's the same to.
Martin
Old Aug 1, 2010 | 08:10 AM
johnyjn's Avatar
johnyjn
Thanks,i can see that the 3dr abc ecu plug has one wire in a different place to the 2wd saff unit but not sure what the wire is.Really could do with a wiring diagram for 3dr and saff looms.
3dr cossie
11
Dec 21, 2015 03:38 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
