Missfire or Fuel problem??
Old Jul 29, 2010 | 07:12 AM
Fordmad!'s Avatar
Fordmad!
Default Missfire or Fuel problem??
My car dosnt seem to like going slow. Ive changed the Spark plugs, Leads, Fuel Filter and it still seems to jump in 4th gear and also dosnt like doing 40 in any gear!
When its ticking over its fine! When you rev through the geras its fine, Its only when you drive slow through town and stuff.
Could the injetors be blocked? If it was the coil pack it wouldnt tick over right would it??
Help please!!!
Old Jul 29, 2010 | 02:12 PM
Fordmad!'s Avatar
Fordmad!
Anyone have any ideas?
Old Jul 29, 2010 | 02:56 PM
Xr2iTurbo's Avatar
Xr2iTurbo
I also had this problem with my last xr3i and my 2i i got now did it also before i put turbo engine in,is it cvh efi engine? Bloke who i got my 3i off had it ten years and it had done it all its life while he had it? Sorry its no help tho sortin ur prob mate hope sum one knows
Old Jul 29, 2010 | 04:09 PM
Fordmad!'s Avatar
Fordmad!
Yeah its a CVH EFI. Its a right pain you have to coast everywhere or keep accelerating!! Getting use to it now but still annoying.
I have a good idea that its a fuelling problem
Old Jul 30, 2010 | 05:35 AM
Fordmad!'s Avatar
Fordmad!
Anyone suggest anything else?
Old Jul 30, 2010 | 06:51 AM
kristinthomas21's Avatar
kristinthomas21
In most engines, the vacuum suction should be constant between 16 and 22 inches. Lower the reading usually means a loss of vacuum, but may also indicate a pressure problem (as in connected to a catalytic converter), the worn valve guides or valve springs weak. Vacuum gradually decreases, while the engine is idling is nearly always the exhaust restriction. Oscillating vacuum reading usually indicates leaking valve or worn valve guides.
Old Jan 28, 2011 | 07:53 AM
car-parts's Avatar
car-parts
Findapart-Used car parts
Default Spark plugs
I had a simular problem with my XR3i, theres that many different car parts it could be, it turned out to be the spark plugs i had some hotter running plugs put in and that cured it. Don't use car breakers for used car parts these need to new. hope this helps
Old Jan 28, 2011 | 08:05 AM
chaffe's Avatar
chaffe
Turbocharging Technician
maybe needs to CO pot adjusted whilst on a gas anylser
Old Mar 2, 2011 | 05:33 AM
Dude72's Avatar
Dude72
I think you have to replace the fuel filter and check the fuel pressure. May be it will help you to solve the fuel problem.
________________________
Cheap Used Cars RVs For Sale
Old Mar 2, 2011 | 06:16 AM
chaffe's Avatar
chaffe
Have you checked the ignition timing with a strobe, sounds like it is too advanced
Rob Wells
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
RSBryden
Sep 6, 2015 08:39 PM
ginger1979
Jul 31, 2015 09:56 PM
