New fuel pump loom.
Old Jul 26, 2010 | 11:49 PM
lee2cossies's Avatar
lee2cossies
Default New fuel pump loom.
Just fitted my new fuel pump loom,but a bit confused with it! Iv had to mount the relay in the boot,passenger side due to the length of the cables.Are most remade looms like this? or as per original fit inside dash?
Old Jul 27, 2010 | 10:09 AM
RS-Stian's Avatar
RS-Stian
www.fordclubnorway.no
Who did you get the loom from? I know that there are some different types of fuel pump looms around so it depends on who made it. The relay on the first loom i got from Prometheus Motorsport was to be placed with the original yellow relay behind the dash. I didn't get this loom to work so i have ordered a new one which goes directly from the battery and back to the pump, not through the original relay like the first one. With this loom i have to place the relay in the boot.
Old Jul 27, 2010 | 10:18 AM
RSRoy's Avatar
RSRoy
Got my loom of CW Looms and also had to place my relay in the boot.
Old Jul 27, 2010 | 12:45 PM
opposite lock's Avatar
opposite lock
i got mine off ryan on here , relay in the boot (not fitted yet)
i,m sure if you asked your loom maker they would supply how you want it , im certainly no sparky but what is confusing you ?
mike
Old Jul 27, 2010 | 02:13 PM
1374lee's Avatar
1374lee
Default protect
Lee,if u had it off Fraser,u can always call over and have a look at my new wiring set up for the fuel pump.
CheeRS.Lee.
Old Jul 27, 2010 | 08:20 PM
lee2cossies
mike
It came from someone local to me,only bit i was confused about was fitting the relay in the boot,would rather it be in the original place,but never mind,still a good quality loom and works fine.
Old Jul 27, 2010 | 08:22 PM
lee2cossies
CheeRS.Lee.
Thanks lee,it came from a guy in cardiff whos making them,its good quality but was a little confuse about the relay in the boot bit! But all clear now.Il come over one day and have a look round you setup anywy if you dont mind.
Old Jul 27, 2010 | 08:49 PM
1374lee's Avatar
1374lee
No probs Leigh,anytime m8.
CheeRS.Lee.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
