Help needed fitting a breather
Old Jan 20, 2005 | 03:10 PM
Max's Avatar
Max
Default Help needed fitting a breather
I have just brought a bailey breather and rocker cover for me car to try and stop it smoking so much.
But I am a little confused on how to fit it exaclty.
I know that the top 2 pipes go to the rocker cover and where the old breather fitted. The little bottom pipe goes to the lefthand side of the block and the bigger one vents to atmosphere.
but what goes here??
This pipe comes out the side of the old breather and goes into the plenum
Should there be a blanking screw to block it up
Old Jan 20, 2005 | 04:33 PM
Dave Henshall's Avatar
Dave Henshall
i screwed in a brass nipple and connected the carbon canister purge line back to it. once the factory brwtaher pipes are all off , u are left witha thin 6mm rubber one from teh purge solenoid at the bottom of the inner wing.
nipple seen here....
Old Jan 20, 2005 | 04:35 PM
Dave Henshall
OR, if its not a green top one, just bung it witha plug
Old Jan 20, 2005 | 06:36 PM
Max's Avatar
Max
nice one mate
I thought it just needed a bung put in it, but wasn't sure
Old Jan 20, 2005 | 07:39 PM
Switch's Avatar
Switch
I was right max ps dont forget to bring the old cam cover round on weds, oh and that office 2000 disk
marky_g
Aug 15, 2015 10:43 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
