what type and how many litres of oil 2wd?
Old Jul 20, 2010 | 08:47 PM
J690Turbo's Avatar
J690Turbo
Default what type and how many litres of oil 2wd?
as above i want to do an oil change before ford fair next month but not sure how much oil to put in as my dip stick apears to have been trimmed down for some reason
Old Jul 20, 2010 | 09:03 PM
Ridgey's Avatar
Ridgey
2wd cossie, is about 4 litres, 15w50 mobil 1.
Matt Lewis Motorsport for your oil and filter
Old Jul 20, 2010 | 09:13 PM
J690Turbo's Avatar
J690Turbo
nice 1
Old Jul 21, 2010 | 12:40 PM
martysmartie's Avatar
martysmartie
I use 10/50 Silkolene fully synthetic less drag at start up then a 15 weight and 50 a nice weight for when hot.
Martin
Old Jul 21, 2010 | 01:54 PM
Depends on mileage, but a 50 weight minimum, or Millers 10W60 fully synthetic.
I run in my 2wd, 1/2 litre above the max mark.
Old Jul 21, 2010 | 04:15 PM
james kiely's Avatar
james kiely
i havent heard of doing that before tabetha ,whats the reasoning behind going the extra half litre?
Old Jul 21, 2010 | 06:15 PM
cossie604's Avatar
cossie604
^^ to try and counter act against surge during hard cornering, ie track use, is the common reason.
Ive started using the latest Castrol 10w60....noticed my oil pressure seemed to be really stable regardless of oil temp with this particular oil.
Old Jul 22, 2010 | 01:24 PM
Nothing to do with surge in my case, mine baffled, I couldn't be arsed with filling with oil every 100 miles or so with a worn engine, so put more into start with, didn't cause any issues at all.
I won't do this when I put me new engine in, as I think the oil/air cooler will add another litre, and so help anyway, with the small capacity, just need to find room for the oil cooler and the steering fluid cooler, got me eye on a lecky steering column hybrid using cossie/sierra and corsa parts, or MGF as these are much cheaper!!
Old Jul 22, 2010 | 05:56 PM
martysmartie
I use Silkolene fully syn (Pro S) 10/50 IMO you should have a 50 weight, dosen't cause as much drag when cold as well like a 15 weight would.
The actual reccomendation for these is 5/30 but IMO that is to thin
I always fill mine below the max line.
The actual capacity is 3.0 litres without filter and 3.4 including filter.
Martin
Old Jul 22, 2010 | 06:14 PM
retro d's Avatar
retro d
Im going to try the 10/60 castrol next as im on millers 10/60 at the moment but not many places stock this.
Old Jul 23, 2010 | 07:51 AM
I think it's called castrol edge now, when I used castrol RS10W60, it was absolute crap, broke down way to easy.
IF YOU WANT REAL GOOD PERFORMING OIL THEN ADD WHAT THE MAKERS HAVE TAKEN OUT,-------- ZDDP, track it down and add to each oil change, oils, all oils were massively better with this ingrdeient.
Old Jul 23, 2010 | 08:09 PM
J690Turbo's Avatar
J690Turbo
a few people have recommended the millers 10/60 so im thinking i will go with that, i put it in my rs turbo last year and that run great on it, nice and quiet too
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
