Various parts - S1 MK3 S2 MK4 1600i - Updated regularly
Old Jul 19, 2010 | 05:37 PM
jimmers51's Avatar
jimmers51
Default Various parts - S1 MK3 S2 MK4 1600i - Updated regularly
To start off heres a spoiler. Genuine Ford, part number: 81 AB B44210 AB
It has a few cracks in the paint and kind of a lump underneath one side as you can see in the pictures.
It's in good condition, not excellent condition but it could be put straight on to a car if your not fussy.
£35, £12 to post, I will package very well.
Front and back seats for a S1 RS Turbo. I will describe each seat in detail below, overall the interior is in good condition, it has all been taken apart and washed in a washing machine so it all smells nice and it is clean. The front seats have the lifting handles on the correct sides.
Driver's seat
Good overall condition, the upper bolster has been repaired, the lower bolster below this has some wear (lighter shade of grey), the middle part at the end that pulls out has been repaired at some point, the material has an extra line of sewing in it, it has a little brown mark on the middle part. One of the lower bolsters has been repaired with different colour material on the inside. All this can be seen in the pictures. The seat pan underneath the middle part is missing a metal clip and the side trims where the adjuster for the seat to lean back or forward are not there.
Passenger's seat
Very good overall condition, two little marks which look like cigarette burns near the top of the inner bolster. Small marks on the middle part. Apart from this it's extremely good condition I would say.
Rear single upright
Very good condition apart from a small rip in the top of the material as seen in the pictures.
Rear twin upright
Very good condition apart from someone has drilled some small holes in the back of the seat metal part and the plug for the elastic to hold the seatbelts is missing as seen in pictures.
Rear bottom bench
Very good condition, small scratches on the bottom metal part.
£160
2 x Fuse box covers, mint condition, no cracks, no splits, good seals, shine well. Come from a MK4 escort.
£5 each, £3 post.
S2 header tank, good condition.
£5 and £3 post
Window scraper seals inner / outer. Sold in pairs. Taken from a mk4. Good condition, see pictures. £10 a pair. £3 post.
Slight bubbles on the end of the outer seals.
Fuel filler neck, I bought this off ebay, it was listed for a rs1600i/s1 rs turbo. Does not fit a s1 so I think it may be for a normal mk3 or xr3i? Any way the part number is 81 AB - 9034 - AD. The metal part at the top is not rotten and is in good condition. £15, £5 post.
S1 MK3 Speedo clocks surround, £5, £3 post.
Chrome alternator shield, surface rust all over the back and some on front, £5 and £3 post.
S1 MK3 Rear strut cover, cracked, £1, £2 post
S1 MK3 Centre console, has a crack in the front, £4 and £5 post as it's quite large
S1 MK3 Door handle trim, £3, £1.50 post
S1 MK3 Door handle trim, 1 broken lug, £1, £1.50 post
S1 MK3 Door handle, £3, £3 post
S1 MK3 Compartment for ash tray to go in plus cigarette lighter which is broken, £3, £3 post
MK3 S1 Lower compartment for tape deck to go in, £3, £3 post
S1 Front grill, has two holes drilled on top to fix down and one of the lower mountings has a piece missing, would still fit in ok by the looks of it. Good condition, would need to be painted if you want it mint. Comes with 80's spec Ford Oval badge in excellent condition. £25 posted.
Rear light bulb holders £6 posted each
Pair 1
Single holder on it's own
MK3 S1 Ash trays x 2, £6 posted each
Exhaust manifold, come from a S2, painted black £25 posted
Wiper motor cover, has been painted black, £6 posted
MK3 S1 Storage compartment that goes down the righ hand side of the dash, has a hole in the bottom about the size of a ten pence piece. £6 posted.
Metal strut tops, £8 posted the pair
S1 MK3 Pair of hella headlamps, £15 plus postage
Cylinder head for 1.6 Turbo. I think this came from a S2 so unsure if it will fit S1 or not so please look at the pictures. The head has been skimmed, valve guides and seats re done. Does not come with cam or followers. £120 posted
S2 carpet, good condition, £20, £10 postage
S1 MK3 Pair of carello headlamps, someone has painted the top black, I would recommend spraying with chrome spray on the backs, £20 posted
MK3 RS1600i front grill, very good condition with all lugs in tact, no damage. Part number: 81-AG-8150-AA £15 posted
Ford P21 Radio
This is an original radio from an Escort MK3, I think these were fitted to the base model Escorts from new.
I have been told this is working but I have not tested myself so it's being sold as untested. £20 posted
S1 MK3 RS1600i XR3 etc rear washer bottle with cap, excellent condition, £12.50 posted
MK3 Header tank without sensor hole, fair condition, crazing to the top and some yellow marking, £20 posted
Centre speaker grill, all 4 lugs in tact, £12 posted
Old Jul 19, 2010 | 05:55 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
no then fella , ill take the two top door trims,
let me know how to pay
also do you have the rears ?
as for the seats , if your willing to split id be very intrested in the rear bench mate ,
depending one price
regards beef
Old Jul 19, 2010 | 07:16 PM
neil73's Avatar
neil73
Pm sent
Old Jul 21, 2010 | 01:44 PM
jimmers51's Avatar
jimmers51
Top door trims sold.
Old Jul 21, 2010 | 05:26 PM
BillyCabrio's Avatar
BillyCabrio
jimmers51 I'll have:
1x Fuse box cover
1x S1 Mk3 Escort ash tray
1x S1 MK3 Compartment for ash tray to go in plus cigarette lighter which is broken
PM me a price chap and i'll send the monies over.
Old Jul 21, 2010 | 08:25 PM
jimmers51's Avatar
jimmers51
Wheels sold, PM sent BillyCabrio.
Old Jul 23, 2010 | 12:23 PM
jimmers51's Avatar
jimmers51
1x Fuse box cover
Sold pending payment
Old Jul 23, 2010 | 12:34 PM
-beefy-'s Avatar
-beefy-
parts arrived on time and as discribed ,
thanks alot matey !!
Old Jul 23, 2010 | 12:44 PM
jimmers51's Avatar
jimmers51
Glad they arrived ok and your happy with them
Old Jul 25, 2010 | 10:06 AM
jimmers51's Avatar
jimmers51
More added above
bassboy
Sep 10, 2015 08:54 PM
sunburstred
Sep 9, 2015 11:24 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
