H/G & Engine bearings
Currently sourcing all the parts to rebuild a block and i'm after advice as to what brands to for
Bearings
GGR Genuine Ford YB or H/D bearings?
Headgasket
Mountune WRC or Cometic multi layer WRC?
Bearings
Headgasket
theyre just not good at staying in one bit to be honest, a few years back there was a patch where the gen wrc gaskets dried up, five engines were done with cometic and all came back for a wrc upgrade
the bastos car you may know, escort cosworth track car had a cometic, he had problems and two engines just on the dyno by another tuner just had problems, so from what i see with my own eyes they are shite
So are they lifting or what ... ?
ive heard people run them before just not on a big spec build with much success
Iv used acl bearings on loads of big power ybs including my own..i like the way you can order them in many different sizes after plaster gauging them..
Also used cometic hg s on many big power engines with no probs although about 5 years ago there was a few that went wrong...
But now with the price of the wrc hg not being so bad theres no point i n using anything else..5 years or so back a cometic was like Ł100 and wrc Ł275 so a lot of difference but now wrc is only Ł125 so why use a cometic at Ł90???
cheers danny
cheers danny
Cheers for the info -
Danny do you supply the WRC gasket for Ł125??
Also seen Matt Lewis is knocking the bearing kit's out at Ł150 so if they are what the tuners would use then thats good enough for me
cheers danny
I listen to the person I use, with his 54 years experience including building engines made/forged bit by bit from the ground up, has his own dynos, etc all the machine facilites you could ever think of, builds many many succesful engines, last year one costing over Ł100,000, had many one off components, was some historic engine, for someone richer than me!!
Plenty of norweigan chaps running 500+ on group a, they seal better due to thier fibrous nature on non perfect surfaces, ie where block has not been skimmed.
As stated above for the cost of a WRC one these days and a proven product then i'll buy one of these.
Just been reading an interesting thread on here regarding bearings, info regarding Mahle Motorsport
https://passionford.com/forum/techni...-cosworth.html
