gt30 compared to t34 .55
i have a bit of a dilema going on so here goes
i have a gt 30 roller bearing turbo with external wg and i also have a t34 currently running a .48 exhaust housing i am looking for a genuine 400 atw hp so question is am i better running the gt30 as it will make the power at lower boost levels and will be less stressed ??/
would a t34 make this power realistically ??
am i better off sellingthe pair and getting a t38??
advise and options please
regards Ian
ps this is 2wd sapph
regards Ian
spec will be
neil roper fast road head
cam choose (need advise)
fardon rods
standard pistons
small turbo inlet
500 cooler with 76 inlet and out (pro alloy)
fidanza lw flywheel
alcon 6paddle clutch
quaife atb diff
turbo cooler
ali rad
looking at running l8 but boostcontrol though turbo smart eboost 2
fardon rods
standard pistons
small turbo inlet
fidanza lw flywheel
quaife atb diff
turbo cooler
ali rad
[QUOTE=martysmartie;5000378]T34.48 will make 380HP all day long, so with a .55 or .63 housing it would easily make 400.
Martin[/QUOT
at the flywheel maybe, atw, not a chance!
Martin[/QUOT
T34's never make big power, i've yet to see a genuine one at 400ATF - So to get 400ATW you are looking at 472ATF which ain't going to happen, even with a T38 you'd have to have alot of goodies and a good map
411 at the wheels with my GT30. Click on the link in my sig if you want to read all about it and the development. You have a played with head as well so even more power will be yours
get a T38 and your car will see 400bhp
mines running T38 , headwork, bd14 cams and greys and it made 400bhp with ease
upping the boost next time too see more ! a GT30 is an awesome turbo tho !
GT30/71, Vipec management and 750cc injectors bruv, awesome upgrade
Luciano
Russ Payne
Sep 25, 2015 08:29 PM
