Fitting 2.0 engine
Old Jul 14, 2010 | 03:50 PM
hineho87's Avatar
hineho87
Default Fitting 2.0 engine
Hi,
Iv got a 1.8 with full exhaust/induction and cams/pulleys. I mite be able to get hold of a 2.0 focus engine. Im interested in this as it gives higher std bhp and also my cams will work better in this engine so can get better gains overall.
What i want to know is will it just be a matter of getting the engine or will i need any other parts? loom, ecu etc. Will the 1.8 gearbox be ok to use and by keeping 1.8 gearbox will it help improve acceleration.
Or would just swapping the bottom end be better option.
Any help appreciated
Thanks
Matt
Old Jul 14, 2010 | 06:37 PM
woolford's Avatar
woolford
gearbox unless you stick 1.8 flywheel on 2.0l and think just ecu.
Old Jul 14, 2010 | 06:54 PM
hineho87's Avatar
hineho87
So can i use the 1.8 flywheel and gearbox? So just engine and ecu will be needed for swap?
Matt
Old Jul 14, 2010 | 07:15 PM
woolford's Avatar
woolford
defo fit 1.8flywheel to the 2.0l engine and use the 1.8box
and 80%sure just ecu
Old Jul 14, 2010 | 08:40 PM
hineho87's Avatar
hineho87
cheers m8 will price up a good 2.0 engine, shud help with acceleration using the 1.8 gearbox
wot if i just got a 2.0 bottom end would that work ok with the 1.8 head and the kent cams that designed for 2.0? jus seen new one on ebay, that way wud no condition of bottom end
Bin told sumwhere that the 1.8 ecu shud be ok, but was plannin on custom map anyway
Thanks
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
