MFi full power enrichment
Old Jul 12, 2010 | 07:09 PM
PaulT's Avatar
PaulT
Default MFi full power enrichment
Mines not working according to my last rolling road visit. What to look at first Silver/Black ecu, throttle switch or what ?
Cheers PaulT
Old Jul 12, 2010 | 08:50 PM
project rs's Avatar
project rs
check tps on throttle body is reading wot and the person on rr needs to have foot firmly planted as if not then tps can not read wot you'll only get it's part throttle, next is to check little black/grey box on side of fuel metering head (emapp or something like that) or could just be it's never been set up right in first place
Old Jul 12, 2010 | 10:47 PM
kermitt's Avatar
kermitt
Was it a reputable RS tuner that set it up before the rolling road session? if so then how long ago?
Might not be fuelling sufficiently so could perhaps do with a setup. This will identify if the little box on the metering unit is faulty. They are about Ł200 from Burton Power.
Old Jul 12, 2010 | 11:40 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
check for 12V at tps when ignition is on. if you have 12v then there is power to the black fuel ECU for cold start and on boost enrichment, for starters.
Old Jul 13, 2010 | 02:27 PM
PaulT's Avatar
PaulT
[QUOTE=kermitt;4995597]Was it a reputable RS tuner that set it up before the rolling road session? if so then how long ago?
It was set up 5 years ago at Nobles in Chesterfield made 196bhp, was happy with the service so went back a few weeks ago having fitted a new cam made 204bhp but full throttle enrichment was mentioned hence the question.
Will check whats already been said and take it from there, the operator also mentioned fuel pump may be tired. We will see.
Thanks PaulT
Old Jul 13, 2010 | 03:38 PM
kermitt's Avatar
kermitt
Thumbs down
5 years ago, wow!
Depending upon how often you use it I would say minimum every year.
That at least is a starting point to get it properly setup to suit the new cam to make sure its fuelling properly on throttle/boost etc.
If its got a vernier pulley for the cam shaft then you are probably as well getting that sorted too whilst on the rollers.
Old Jul 13, 2010 | 06:02 PM
PaulT's Avatar
PaulT
Originally Posted by kermitt
5 years ago, wow!
It had a full set up 3 weeks ago everything set fine these issues were remarked on that needed looking at.
PaulT
Old Jul 13, 2010 | 06:06 PM
stwibs's Avatar
stwibs
paul have you the supplement manual ? tells you how to check certain things fuel related in there.
Old Jul 15, 2010 | 08:58 PM
crighton13's Avatar
crighton13
sounds like a lil like sumones i know :P
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
stevierob
Sep 7, 2015 07:09 PM
