loosing boost ? MAP
Good morning ,
having trouble keeping up boost.
car is sierra 92 , 4x4 , MSD stage 2 chip closed loop , RS500 cooler , greens , T3 , scorpion exhaust no cat , cone pipercross filter.
- checked the system out with my air compresser to 2 bar no leaks.
- tried to wind the actuator further no luck either ( is a brand new -31 one )
- fuel pressure is spot on 3 bar on idle
- car goes overboost 1,5 bar , stable to 1,2 bar . I should get 1,7 bar stable 1,5 bar.
Only thing I donnot know what is the difference in 2 bar and 3 bar MAP does anyone have the serial numbers for these ? I assume I got a 3 bar
MAP sensor.
Steven
MAP sensor.
Steven
A 2 bar sensor can't measure these kinds of boost - max. is 1.1 bar.
So you probably should have a 3-bar map-sensor (ask MSD).
Check voltage from map-sensor with ignition on, engine off.
2.2V is 2-bar, 1.8V is 2.5 bar and 1.5V is a 3-bar map-sensor.
2-bar is aps-02, 2.5 bar is aps-06 and 3-bar is aps-05.
2 BAR MAP is standard item, when you go to stage 2 or above you need a 3 BAR MAP sensor, Atmospheric pressure is +1BAR so the 2 BAR can only see +1 BAR positive (Boost) pressure you then have 2 BAR total, whereas a 3 BAR can see +2 BAR boost.
You have a 3BAR map sensor otherwise you would not have the boost you do it would also be dangerous, I would check the actuator it should be a -31 or -34 type, the springs go weak after a while.
Martin
Martin
Hmmm, checked that also just comparing to my fuel pressure gauge and they are going equal up so ...
hen it runs on idle I got - 0,8 bar pressure coming of throttle -1 bar what I think is correct so it cannot be that far off
Steven
Steven
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
