2wd saff speedo and stereo stopped working???
Old Jul 9, 2010 | 06:44 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Default 2wd saff speedo and stereo stopped working???
As above, got into the car one afternoon and had no dash lights, speedo or stereo???
still have rev counter and full use of all other electrics
Any suggestions as its doing my head in
Old Jul 9, 2010 | 06:51 AM
Mike Kerbey's Avatar
Mike Kerbey
Does your interior lights work, I know these are on the same circuit as the radio, may have blown a fuse for that. Your speedo is just a cable so cant be electrical.
Old Jul 9, 2010 | 03:20 PM
martysmartie's Avatar
martysmartie
As said speedo is purely mechanical affair so thats another problem, the dash lights are protected by fuse 22 the contacts corrode leading to this problem but then the rev counter would not work but check this first. The radio has two lives one is permanent and the other is switched ignition, so as said make sure interior lights work.
Martin
Old Jul 9, 2010 | 04:55 PM
ShiftyOldScoob
Thanks for that guys!
I checked the speedo drive on the gearbox and all was fine so I'll pull the clocks out and see if it's detached itself from there...
As for the interior lights I'm not 100% sure...I'll check when I get home this weekend
Old Jul 11, 2010 | 08:24 PM
martysmartie
The cable more than likely has snapped as they "Clip" which is difficult enough to get off by trying in the dash end so doubt it would of come loose.
Martin
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
salsheikh
Jul 30, 2015 08:45 PM
