2wd saff speedo and stereo stopped working???
As above, got into the car one afternoon and had no dash lights, speedo or stereo???
still have rev counter and full use of all other electrics
Any suggestions as its doing my head in
Does your interior lights work, I know these are on the same circuit as the radio, may have blown a fuse for that. Your speedo is just a cable so cant be electrical.
As said speedo is purely mechanical affair so thats another problem, the dash lights are protected by fuse 22 the contacts corrode leading to this problem but then the rev counter would not work but check this first. The radio has two lives one is permanent and the other is switched ignition, so as said make sure interior lights work.
Martin
Martin
Thanks for that guys!
I checked the speedo drive on the gearbox and all was fine so I'll pull the clocks out and see if it's detached itself from there...
As for the interior lights I'm not 100% sure...I'll check when I get home this weekend
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
