wheel bearing
hi all
just wandered if its normal for a 03 plate mk1.5 focus to eat 4 wheel bearings in 2 years
what could cause it ? or is it just because im buying the cheap ones all the time?
ive had the car 2 years got one replaced(forgot whitch side) when i bought it,then about a year later got the other side done when it started whining.then aprox 6 month later the first one i had replaced needed doing again.
anyways 2 months ago the car scraped throw on the mot with advisorys on the front brakes so i thort i would get the whole lot done at once.
bought new front discs and pads and rear shoes hubs and new rear bearings to go in the new hubs.
just been to london and back(nearly 1000 miles) and the rear driver side is making a whering noise.
since the new bearings were fited ive probebly done at most 2000 miles
so any thorts?
john
so any thorts?
john
Does your car have abs? If so it can be very heavy on wheel bearings. The only advisable things are to avoid heavy breaking and cornering.
Mine is heavy on bearings too as it's on coilovers. Might be worth trying a better quality bearing?
Non abs :O hmmm I'm not sure then
Maybe try the genuine ford parts. I'm not saying it will 100% work. But it might be worth a go.
With coilovers I can be changing wheel bearings at least once a year. If it makes you feel any better
You got non standard wheels on it? If so what offset are they? You ideally want ET49 but anything less than ET42 and it will put a big strain on the bearings and cause them to fail early.
john
Adam Graham
Sep 6, 2015 06:04 AM
